Stu Paddasso
Not sure what a full battery cycle is. Can you give a full run-down procedure?Sometimes running the full battery cycle few times helps.
Hi,Not sure what a full battery cycle is. Can you give a full run-down procedure?
@Shanling the mqa is not working. Tidal app. Please fix this as it's putting the m8 and shanling to a bad support organization.Please what exact issue are you facing? We are aware of issue with MQA playback from Tidal, but it should otherwise work fine.
Please which firmware and app version are you running? Will check on it.
Combination of old battery and not exactly accurate battery indicator most likely.
Been that way for a very long time. This is the reason I switched to Apple music for hi-res FLAC about a year and a half ago.@Shanling the mqa is not working. Tidal app. Please fix this as it's putting the m8 and shanling to a bad support organization.
Hi,@Shanling the mqa is not working. Tidal app. Please fix this as it's putting the m8 and shanling to a bad support organization.
I can tell you that my Shanling M6 Pro 21 with Android 7.1.1 Tidal Android app (any version beyond 2.86) still does the artifact-noise thing while playing MQA tracks but Tidal in UAPP is fine, no glitches as far as my experience.Hi,
Read the other threads about Shanling.
Shanling IS a bad support organization.
This is now a fact...
When was the last significant update to their formerly flasgship device the M8 (that I own but will probably sell soon) ?
Probably months ago AND with only font colour fixes as an update.
The M8 is a fantastic device.
But as usual, totally let down by it's manufacturer (how will probably come in here just to claim they're supporting the device and provide a link to the last update).
Anyways, I think there are one or two apps like UAPP/mConnect/BubbleUPnP that support Tidal.
Have you given those a try to see if going through thopse you have better support for Tidal ?
It's worth trying I think.
I would do it but I do not have any Tidal account...
Regards.
I have been noticing the Tidal MQA files are in fact disappearing on their service showing still in my playlists, though the link is gone, have to go to the search find the album or track again and add the FLAC (usually) to my playlist, this as Tidal works MQA out of its library.I can tell you that my Shanling M6 Pro 21 with Android 7.1.1 Tidal Android app (any version beyond 2.86) still does the artifact-noise thing while playing MQA tracks but Tidal in UAPP is fine, no glitches as far as my experience.
Somehow UAPP's developer got around what ever glitches that plague anyone running a less-than-Android 10 device have when using Tidal MQA. As time goes on I'm not sure Shanling's team will ever fix it but one never knows. With my M6 Pro 21 I keep the older 2.86 version of the Tidal Android app (still working so far) and a constantly updated version of UAPP. Best of both worlds.
This has been ongoing issue since August last year, it's due to changes on Tidal side. Our software team so far wasn't able to adjust our Android 7 system for this.@Shanling the mqa is not working. Tidal app. Please fix this as it's putting the m8 and shanling to a bad support organization.
Have any question about our players? Just PM me or send me email.
Stay updated on Shanling at their sponsor profile on Head-Fi.
Thanks for your honest reply.This has been ongoing issue since August last year, it's due to changes on Tidal side. Our software team so far wasn't able to adjust our Android 7 system for this.
As mentioned by other users, running Tidal through UAPP and its audio processing works fine for MQA playback.
Pls do fix tidal as it's now broken for.people who.just use the tidal app only were are customersThanks for your honest reply.
Which reads : "our software team (so we suppose they're a real team of several people) is not able to solve a problem a guy who develops his app as an amateur in his spare time could do".
Maybe you should ask the guy developing uapp if he can help you sorting things ? And give him credit for that if he can solve it for you...
I have noticed this as well, sometimes is replaced by a hi-rez file, but usually, it is Redbook.I have been noticing the Tidal MQA files are in fact disappearing on their service showing still in my playlists, though the link is gone, have to go to the search find the album or track again and add the FLAC (usually) to my playlist, this as Tidal works MQA out of its library.
Is anyone else noticing that.
