Ian S
- Jan 5, 2013
@Xoverman "very rewarding to add 4 tant capacitors across the XILINX ( USB side ) bypass capacitors".
Did you try that? Which caps did you change?
I'm just probing the board now to try and identify which MLCC to swap to tant poly.
Instead of 22µF MLCC for the Set cap near the XTALs, should I fit tant poly 22µF? Was there an audible improvement?
Have you tried sticking damping pads to the case on the SU-6 to reduce vibrations?
Which pins did you join that 100µF cap that's bent over near the white socket for the front panel display? Did that make a difference?
Did you find the way to set your PC and SU-6 to Asyncronous? I saw in the SU-6 driver (I have 5.12) that the input & output latency are about 45ms. And ASIO is not active.
