deleted
problem with tl783 is that as the voltage goes up more and more power is wasted in the control resistor. And those zeners won't save the regulator from blowing up as
they will turn to dust just as quick. Best not to use over 150v. Although we both know someone that uses them at 500v.
much better is kerry's grhv-mini regulators. much more energy efficient, 1 module that bolts to a heatsink and is the size of a to-264. And rated up to 500v.
running the transformer on the 100v taps long term is a very bad idea. eventually the internal transformer temperature fuse will open, and then when you short
it out, the transformer will eventually smoke. i have a 717 here that did that. The result after shorting out the fuse was the high voltage windings shorted to each other.
more and more people are doing stuff like this, may be time to get new transformers quoted that fit into the existing space. Better would be a toroid turned sideways.
Would it makes sense to raise the bias current as well on my SRM-252S by replacing the D4 red led with a TL431 set at 2.5v?
My amp is vented on the top and I have a 12v 1.8A ifi PSU but I'm wondering if a 2.5v reference could be too much for this amp or not.
Atm I have a GREEN led instead of D4.
(Attached the schematic for reference)
Yes it seems wiser not to try 2.5v with the 252S.
I've replaced the red led with a green one so the current is still a bit raised, it's better than nothing
I'm gonna order a pair of LM385 to do the same on my 252S right away
