- Oct 7, 2015
Any one able to upgrade the firmware of the SU-10? I can't get the program to connect to my PC.
Nevermind, solved it!Any one able to upgrade the firmware of the SU-10? I can't get the program to connect to my PC.
I also in Sweden, alos with a D1SE and wounder the same....I wonder how this compares to the VMV D1se?
There's a new review up on Soundnews.net:I also in Sweden, alos with a D1SE and wounder the same....
Someone in comments under a review said it does run hot. Not sure what to think.One thing to consider. According to their spec sheets, the D1SE only uses 5W of power, and it ran pretty warm (I once owned one). The SU-10 uses 30W of power and it's chassis isn't that much bigger than the D1SE, so I would't be surprised if it ran quite hot to the touch!
I got mine today! It's warm, but nothing concerning. Breaking it in now. Just ordered the Soloist today.Someone in comments under a review said it does run hot. Not sure what to think.
https://soundnews.net/sources/dacs/the-one-to-beat-below-1k-smsl-su-10-dac-review/
Is this for the Dec update?There are no stutters after the firmware upgrade.
