boodi
- Nov 19, 2001
there 's a free apk mod ... ,It cost $3 a month to use the full app?
I bought the 9$ forever version
Am still using the remote for the WM1A/Z. Unfortunately this is really expensive now, even if you can find them on the Japanese shopfronts.Just ordered a Fiio Bluetooth remote for my WM1ZM2.
The Sony remote is good for using while mobile, as it is small enough to be unobtrusive, and fit on a lanyard looped on your hand. The WM1A/Z (1st or 2nd gen) can be in a pocket, belt pouch. I used my WM1Z like this for a long time.Am still using the remote for the WM1A/Z. Unfortunately this is really expensive now, even if you can find them on the Japanese shopfronts.
Heard from Sony staff that this has been discontinued.
Now I want one of those Sony remotes. Not paying $150 used without the clips though. The FiiO would work better with my desk setup since it has a wake function though. Thanks for the recommendation.The Sony remote is good for using while mobile, as it is small enough to be unobtrusive, and fit on a lanyard looped on your hand. The WM1A/Z (1st or 2nd gen) can be in a pocket, belt pouch. I used my WM1Z like this for a long time.
For use when at your desk, around the house, etc, the Fiio RM3 is more functional than the Sony remote. The RM3 has a wake function, so can turn the display on/off with the remote, adjust volume, next/previous track, etc. Even has a mouse function, which may be useful for some circumstances.
The RM3 is highly recommended.
Sony WM1AM2 was launched on June 2022, assuming that Sony will only update every 5 years, next update might come up around 2027. Why not getting second hand while waiting for the M3 to come ? the price drop should help offsetting the price drops when the M3 launched, at the same time you can enjoy this awesome audio player.Hey guys in your opinion should I jump the gun and get this dap right now or wait some time for a newer variant of it ?
The fact is there are still many owners of the the M1 Walkman who won’t even consider upgrading to this current M2 Walkman as they probably feel that their Walkman sounded better or maybe there something that they didn’t like about the current model.Sony WM1AM2 was launched on June 2022, assuming that Sony will only update every 5 years, next update might come up around 2027. Why not getting second hand while waiting for the M3 to come ? the price drop should help offsetting the price drops when the M3 launched, at the same time you can enjoy this awesome audio player.
Isn’t she born in Kaohsiung City, Taiwan, she is from an ethnic group called Amy.
https://zh.m.wikipedia.org/wiki/A-Lin
https://zh.m.wikipedia.org/wiki/阿美族
There’s a Chinese program that featured her beginnings from her hometown in Taiwan:
Am currently using one of these wooden stands just because I like the look of it.Now I want one of those Sony remotes. Not paying $150 used without the clips though. The FiiO would work better with my desk setup since it has a wake function though. Thanks for the recommendation.
Does anyone have a DAP stand they can recommend? I guess a phone one would work too.
The wood one is nice. Yeah I wouldn't use a magnetic one since I paid $$$$ for the thick copper housing that shields better, allegedly.Am currently using one of these wooden stands just because I like the look of it.
But in the past, I've used the sleek magnetic ones. There are about a gajillion variants out there at different prices.
Only drawback is you've got to stick on a metal plate (usually comes provided) on the back of your case. This worked well enough to hold up a WM1A. The magnet didn't interfere with the operation of the DAP... but I'm sure someone will jump in and "prove" that it will, so up to you.
Yeahhh... that's not really how magnets work.The wood one is nice. Yeah I wouldn't use a magnetic one since I paid $$$$ for the thick copper housing that shields better, allegedly.
I wasn't being serious in case that wasn't obvious enough.Yeahhh... that's not really how magnets work.
The magnet in the stand is strong enough to hold your hardware but the strength of the field drops off within a few mm from the surface. I don't think there's enough mf radiation to generate any current in a static object, even if it's copper.
The drawback about this wooden stand is you can't connect the USB-C to it to charge while vertical; there just isn't enough height clearance. Fits great horizontally, though; vertical, it's just a holder without charging.
Sometimes it's kinda hard to tell on the forums. Had someone else elevate his BP over something I said a few posts back.I wasn't being serious in case that wasn't obvious enough.
Pezin & Hulin Bamboo Phone StandDoes anyone have a DAP stand they can recommend? I guess a phone one would work too.
