SoundMagic P22BT Portable Wireless Headphones On-Ear Discussion and Reviews
May 30, 2018 at 12:35 PM Thread Starter Post #1 of 2
Dobrescu George
Reviewer: AudiophileHeaven
Bucharest, Romania
I am making a thread about those headphones, I am a reviewer who will review them, but not affiliated with Soundmagic or anyone else.
They can currently be found here, although they should become available in other places as well: http://www.hifiheadphones.co.uk/soundmagic-p22bt-portable-wireless-headphones-black.html
SoundMAGIC P22BT
Listening on the move is being redefined with SoundMAGIC's even more portable and convenient wireless P22BTheadphones. With the P22BT version, SoundMAGIC have added Bluetooth wireless connectivity with high-resolution sound while retaining the same powerful bass response with consistent and balanced midrange as the wired model.
To enable high fidelity sound, the drivers of the P22BT have been tuned for a dark and warm sound concentrating on a deep and pleasing bass response with balanced midrange and distinct instrumental separation. It is a feat of engineering of SoundMAGIC to achieve sound of this degree in such an affordable and lightweight headphone.
SoundMAGIC P22BT is a truly portable headphone equipped with a foldable headband ideal for packing in a bag or suitcase when out and about. Soft, leatherette earpads equipped with memory foam gently mould on the ear to create a comfortable wearing experience.
Always moving.
Inspiring Wireless Sound
Expertly tuned drivers of the P22 are able to produce a muscular bass response with consistent and balanced midrange, and sparkling trebles polished off with lucid instrument separation. Bluetooth v4.1 wireless transmission provides rock-solid connectivity that streams high-quality audio to the P22 headphones perfectly.
Highly Portable
To make the P22BT a genuine portable travel headphone it incorporates a folding mechanism on the headband making it ideal for taking with you without making a big space impact in bags or suitcases.
Robust Design
With the strong thermoplastic resin and metal components used in the construction of housing and headband, the P22BT headphones surprise with its strength and hardiness for such a lightweight design.
TECHNICAL SPECIFICATIONS
  • Driver: Dynamic 40mm Neodymium
  • Frequency range: 30Hz - 20kHz
  • DC Resistance: 32Ω
  • Sensitivity: 95dB
  • Maximum input power: 100mW
  • Weight: 85g
  • Bluetooth version: v4.1
  • BT frequency range: 2.4 - 2.4780 GHz
  • Range: 13m
  • Energy Consumption: Class 1
  • Music playback time: 18-20 hours
  • Talk time: 13-15 hours
  • Standby time: 640 hours
  • Audio output: CD sound quality, 44. 1.48 kHz 16bit stereo
FEATURES
  • Portable comfort united with compelling sound and wireless connectivity
  • Heavy bass response with balanced and accurate sound image
  • Bluetooth v4.1 wireless connectivity
  • Capable of achieving high-resolution audio
  • Closed earcup design for increased sound isolation
  • Flat cable design with anti-tangle properties
  • Soft and comfortable memory foam earpads
  • Lightweight build with folding headband
