motoman4540
- Jan 22, 2016
My setup: a 2014 iMac with i7 intel processor, 24 gig RAM, 1 Tb fusion drive, an O2+ODAC rev. B and a set of Sennheiser HD650 headphones. All music resides on a Netgear 516 NAS in FLAC, probably 50% 16/44kz, and the rest 24/92 and some 24/192. Music is played through the iMac using VLC or sometimes Plex
The problem: I have been happily using my ODAC and HD650's since November 2015. Everything sounded great . . . until yesterday. Then, I sat down to listen to some old rock (Yes, Fragile, Roundabout) and the music sounded very distorted, like a very bad quality recording. I listened to a couple of different versions -- all sounded distorted. Then I played it on my audiophool stereo system -- sounded great. Then I put on my "test" FLAC -- an excellent quality recording that I use to compare stereo components -- through the ODAC, and got the same distortion.
Now in troubleshooting mode, I did the following:
- checked to see if it was the headphones by plugging them directly into the iMac. Played fine, so it wasn't the headphones, the server or the connection between the server and the iMac.
- Swapped USB cables between the iMac and the ODAC. No change in the distortion, so the cable was not the problem.
- Verified that the sound settings on the iMac for the ODAC were 24/96khz (also tried 16/48K).
- Hooked up the ODAC to my Macbook Air -- to my surprise, no distortion, albeit the volume was softer and needed higher gain. Seemingly, there was no problem with the ODAC, therefore, and the problem was somewhere on the iMac.
- Switched to another USB port on the iMac. Still the same distortion.
The USB ports on the iMac seem to work fine for things like data transfer to a USB drive, my iPhone, even a desk phone with a headset that connects to the computer via USB for things like Skype, FaceTime or Google Voice.
Other than to eliminate the ODAC as the problem,Tech Support at Mayflower Electronics was useless at this point, now that I had figured out that the ODAC was apparently not the problem. The tech support guy said he didn't have a Mac so he couldn't help me.
I thought that there might be some driver that got corrupted for some reason yesterday, which would explain why swapping USB ports didn't fix the problem, but it doesn't seem like the ODAC needs any drivers, and as I said, the ports seemingly work fine.
So . . . what do I do?
