I can imagine its a bit confusing what i have been doing with all the mods sofar.
So ive been drawing my progress step by step until my last finding.
Starting with the schematic of a stock Dave:
I'm solely focussing on Dave's analog circuit's power section. The 5VDC from the PSU is for digital circuitry and pulse array.
I never made any changes on my Dave's analog audio path because thats perfectly implemented and i dont want to mess that up.
As you can see, Rob placed a LC filter to dampen RF noise from the power input. This is placed near the white Molex PCB connector. From there PCB tracks run straight under the display to the regulators located on the far right. after the regulators a dual parallel cap setup is placed to keep equal track distances to both channel's OP transistors. I coloured the positive voltage rails in Red and the negative rails in Blue. Circuit ground is in black.
Im naming my mods alphabethically to give the order in time that i placed / tried them.
So lets start with my first attempt to add the TDK ultra low ESR caps on the regulator's outputs.
Left schematic Mod A 1st attempt:
I was puzzled to why suddenly the bass mostly disappeared, Dave sounded totally wrong, i really thought Low ESR would make a good voltage buffer, well i thought the analog amp circuit must be too much influenced.. so i took the caps out.
Then i tried them on the input side of the regulators as shown in the middle figure, 2nd attempt.
Now we are talking! i was greeted with enormous ultra sub bass which initially made me think it is artificially boosted bc it stood out of other frequencies.
Later when i got a TT2 to compare it to i found the sub bass was actually on par with the TT2. Hm.. so why the mid range kept behind.. i like the fuller sounding mid part of the TT2. Dave sounded more open in trebble and with better transparency and details still.
After some time brainstorming i had a hunch.. Since on the output side more caps in parallel on the original dual caps made it worse.. what if i change those dual caps to a single setup? .. So i changed the circuit as shown on the right figure Mod B.
What the F. Omg.. this sounds much fuller.. the mids were lifted to TT2 level.. theres was alot more energy to the sound and the treble could get quite loud, not so much digitally harsch but some tracks made it less nice to listen to. Overall this was amazing and i started posting about what i heard.
Also the Mscaler's transients became more evident in the midrange.. not just some high frequency room reverb.. but full bodied texture to instruments.
After this i played with different brand and type of caps and even added 2 more TDK caps on the input side where a parallel setup didnt have such negative effect.
This gave even more control on my headphone's drivers.
So i listened for a time until another Dave entered my house.. a Silver stock one equipped with a Sean Jacobs cap board, sadly the DC4 unit didnt came along..
I switched back to totally stock and compared my black Dave to it.. Oof.. this sounds so thin by comparison .. nice in balance and clear sounding but cold and not engaging.
Where is the rumbling sub bass..?
But it gave me the opportunity to try that Sj cap board on my Dave.
So i installed it making my Dave's circuit as shown in figure under:
I started listening.. but.. this was not as i expected.. it sounded weirdly congested again.. some areas of the frequency spectrum were 'damaged'
actually a similar effect as the dual cap setup on the regulator output. Hm why is this happening.. the Sj cap board has a big capacitance and quite low ESR..
I reasoned before that an audio modulated current has a big influence on Dave's Amp's behaviour.. it can detract parts of the frequency spectrum as i noticed.
It all has to do with (de)charging hardwired caps via long(er) wires/PCB tracks and this is being amplified by the Amp's feedback design.
So i came up with the idea to significantly increase the resistance between the SJ caps and Dave's input with 1 ohm .. one might think this is a bad step.. but my tripple TDK ultra low ESR caps work as a voltage buffer(battery) so i only need to keep them charged by the PSU where the PSU cant boost big currents.
Now theres a big damping between the cap groups not being hardwired, stopping the interchanging currents between them or make them much delayed so to speak.. out of the audible frequency range.
Ohmy yess ..this sounds marvelous.. the Sj cap board doesnt break down the sound anymore and my Dave sounds full and authorative again..
wait.. i even hear improved transparency and deeper details.
But wait.. arent there more hardwired caps in Dave.. yeap.. the first LC filter caps are hard connected via a coil to my TDK caps.. so i will place another resistor in between those.. but make them 0,47ohm each to keep under 1ohm total otherwise the 15v voltage drops to much by current demand and bias of the class AB amp stage.
Damn.. Dave opened up even further.. such balance and transparency i never heard before.. all congestion totally gone.. enormous sub bass to sky reaching highs
and that realness just toxicating.. the mids fully textured.. this is hard to beat by anything, it sounds like Rob's digital masterpiece and pulse array just lost all constraints and can breathe.. it drove me to tears of emotion listening and hearing yet more into my music.. just Perfect!
Since the Sj cap board isnt mine.. i took it out leaving the resistors in place and found there was no easy hearable change to the sound..
So the final circuit now looks like this:
Mod D&F: resistors in place
Hoping not to have bored you all with my crazy modding
i'm going back to Bliss
