Ben86
- Jun 24, 2015
M1S is worst than the R3ii and the V3. But I don't know how R3ii sounds, so may it be according preferences to choose between these two.Just stumbled across the Tempotec V3 recently and I am seriously thinking about adding it to my shopping list. It's kind of like if the Shanling M1S and the hiby R3 II had a baby it would be the V3! I am looking at everything from the Hiby R3 II to the RS2, R5 gen2 and the M1S.
The V3 could replace the R3 II on my list if indeed it does sound better than the R3 II as many seem to think it does. Hopefully by Black Friday my go to date for my next DAP the V3 will get some more attention. I would love to find some comparisons between the M1S, R3 II and this V3 mostly for sound quality. There are a few comparing it to the R3 II but not the M1S.
I don't believe in saying best or worst just sounds different. Given the hardware in the M1S and Shanling's experience making audio gear I can't imagine it sounds worse. I am looking for a DAP that pairs well with my warm sounding headphones and from the reviews some say the M1S does not match well with warm sounding headphones.M1S is worst than the R3ii and the V3. But I don't know how R3ii sounds, so may it be according preferences to choose between these two.
if you are on v0.4 or earlier you need to do manual update the update is even posted here several pages backanyone managed to update this thing yet?
updated mine when I got it, using the provided firmware on their website, put at the root of the SD card, with no issues whatsoeveranyone managed to update this thing yet?
Does the SD card has another files?I am on v0.4 trying in the sd card doesnt work
did you extracted the file if so try another sd card some ppl had problems with some sd cards don't know if it's the format or the card itselfI am on v0.4 trying in the sd card doesnt work
The 0.4 was not bad, just flat, very flat. The 1.0 gives it personality. Both are ok according tastes.yep worked with another sd card tho it had loads of files,
thanks for quick help one and all, basically wanted to try the dap with the amazing Utsusemi amp
Mine does not hiss with any external amplifier that I've tried, oppositely - I think that when V3 is connected to an external amp, it helps to reveal its AKM DAC sweet sound and musicality even more, and sound become even higher quality/price ratio. One of the best daps that I've ever had according to price/sound quality. Very happy with my V3, enjoying music with my big headphones when connected to an external amp.problem it hisses with the amp unfortunately, cheap internals i guess
I haven't experimented any hiss eitherproblem it hisses with the amp unfortunately, cheap internals i guess
