CAJames
A question please ladies and Gents...
When i have read about microphonics prior to playng with 6c5 series... i assumed it was referred to picking up on desk born noises .. for example, i had some Kenrads that picked up touching the desk they were on let alone a light tapping! THose noises are clearly reproduced in some tubes and i assumed with was the microphonics being mentioned. BUT, with some 6c5 tubes im hearing that when i hit the pause button on the music, there is a slight ringing. And with the headphones set to off position,
you can quite clearly hear the music playing on the "tubes" themselves. In all instances, im referring to sounds after warm up, so its not the "otherworldly" warm up noises im referring to. Could someone kindly explain the correct terms to describe what im hearing? Thanks in advance.
I don't claim any special authority in "tube noise taxonomy" but what you describe is what I'd call microphonics. To me, microphonics means turning any kind of vibration into audible sound, whether that is produced externally (e.g. by tapping) or just from playing music thru the amp. Or put another way, if it isn't the "static" or "frying egg" sound produced directly within the tube itself it is probably microphonics.
