Trying to use a receiver to power headphones, met with audible hum and white noise
Mar 26, 2014 at 7:33 PM Thread Starter Post #1 of 3
NotaLefty
Hi, I just dug up an old Pioneer VSX-451 to try and power some Sennheiser HD700's. The receiver is connected to my computer. When my headphones are plugged in, I get a loud hum and white noise. Hopefully this is a simple fix... anyone have an idea as to what's wrong?
Also, would using this receiver provide any benefit over having it directly plugged into an Asus Z87-C motherboard?
Mar 26, 2014 at 7:40 PM Post #2 of 3
Drop the receiver, unless you're planning to power a pair of near-field bookshelves. I'm not familiar with that particular model, but based on specs, I wouldn't put my HD700s anywhere near it.
Spend the money, buy a nice dac/amp. Or something relatively cheap, that actually pairs well with the HD700s. Like the HRT Microstreamer.
Don't spend 500+ on a headphone, then run them straight out of your mobo. Not worth.
Mar 28, 2014 at 12:44 PM Post #3 of 3
You could try plugging into the ASUS integral sound card... Hopefully that will at least alleviate the hiss and noise.
I doubt it will do those cans justice though.  You're going to need a better DAC and amp to push the HD700 correctly.
