hpamdr
- Feb 11, 2015
No this is not a cable comparison.But you basically confirmed you heard a difference, one being smoother than other and both being digital cables.
In DAC, you have 3 type of input, usb, spdif/BNC/AES, IIS wit 3 kind of circuit (for extensive comparison)
- USB need an internal board with re-clocker and buffer in best case to fill I2S input, with Xmos chip usb was limited to DSD128, then 256 and now up to 512 or 1024. The usb interface act as a complete decoder...
- SPDIF / AES /BNC is normally limited to 24bit/192khz (no pure DSD normally DOP up to DSD64) (No major difference between AES,BNC and SPDIF exept for optical wire where a optocoupler play a role) This is the oldest interface and during ages all have been done and known to do best quality. AES was the most used in pro audio studio due to solidity of the plug and the 110Ohm cable typology. This need some circuity also inside depending of the DAC chip.
- i2s bypass almost everything and goes to dac chip. (protocol is limited to DSD1024 but in fact by DAC chip resolution)
