Plus a DAC. For IEM:s only for me it is overkill...But I do like my V222+V850 stack for headphones?? HPA V222 does not take up much space ...
Violectric V222 and V202
- Thread starter Ichos
- Tags
- v202 v222 violectirc
Hatmann
- Jul 28, 2002
The V222 is the same size as the little Schiit Bifrost2/64.?? HPA V222 does not take up much space ...
Its size is one of its many pluses.
This might have been answered before, but is there any point getting the v222 over the v202 if I am using a single ended dac? I'm using the mojo 2
oqvist
- Oct 28, 2004
Doesnt matter if your dac is balanced or notThis might have been answered before, but is there any point getting the v222 over the v202 if I am using a single ended dac? I'm using the mojo
Pharmaboy
*** not with the ability to set 'pre-gain' at -18dB via the rear dual DIP switch sets.
When you're right, you're right.
I would say Bifrost is a nice mid-size DAC. A small one I used to run was the Grace balanced SDAC.The V222 is the same size as the little Schiit Bifrost2/64.
Small enough to just run off the USB power which was handy.
V222 and Bifrost 2/64 is a nice pairing. If your not OCD and don't mind a 90 degree turn it'll sit on top.
Pharmaboy
An 87 degree turn would be maddening.If your not OCD and don't mind a 90 degree turn it'll sit on top.
oqvist
- Oct 28, 2004
My v222 run hot like crazy wouldn´t stack on top of itI would say Bifrost is a nice mid-size DAC. A small one I used to run was the Grace balanced SDAC.
trickyRoadsDummyTOOL
89° would be perfectly fine, at least for me, because it's a prime. Not the only reason I am saving my money for the V550, it's easier to align.… fits better in this regard, too.An 87 degree turn would be maddening.
Fegefeuer
- Mar 17, 2011
Now where are the impressions?
It is difficult for me to convey my impressions in English.Now where are the impressions?
Great sound!!!
Fegefeuer
- Mar 17, 2011
Don't worry about your Englisch. Just use a translator to help you with it. It can only get better.
jonathan c
.... if it's not a right angle, it's a wrong angle? ....An 87 degree turn would be maddening.
With those adoreable little components, it's sure a-cute angle (or am I being obtuse?).... if it's not a right angle, it's a wrong angle? ....
