Most headphones can be run balanced by swapping the cable and balanced output on V222 is quite a bit better than the single ended output. I would rather get the V222 and swap to balanced cables on those headphones that have one connection for each cup than go for a v202.
+1 on this comment.
Even though I'm using SE input cause my Lampizator dac is SE, I still prefer using the balance HP output of the v222. Slightly wider soundstage with better separation.
Better go for V222 @plzTJ
V22 ordered!, now I have to wait at least a month... what's wrong with this amplifier that is in almost all stores, is it out of stock or waiting for units? hype?
I looked all over the place for a V222 and the only store that had them in stock was Thomann, so I ordered on Thursday and it arrives lunchtime today - not bad Germany to UK with a weekend in the middle.
