Gain switches setting inside cool me down. I only owned three headphones, two of them are very easy to drive (TH610, Verisonix N501) the other one needs some power (T60RP). Because of the power gap, I don't want to open the case usually.Violectric V101 - About €700 - Most affordable Violectric amplifier - Made in Germany. Pre gain switches are located inside. Amp circuit is G111.
Violectric V222 and V202
- Thread starter Ichos
- Tags
- v202 v222 violectirc
I think that there is going to be another model, still less expensive than the V202, with gain switches at the outside.Gain switches setting inside cool me down. I only owned three headphones, two of them are very easy to drive (TH610, Verisonix N501) the other one needs some power (T60RP). Because of the power gap, I don't want to open the case usually.
evhvis
- Jan 28, 2013
The spec has been up on the Violectric site for about a week and it is the same output power as the V340.Amplifier technology is the same as the V340 series. Maybe a couple of tweaks. Class AB as always. Exact power output not yet specified.
giuseppe75
When are the new releases planned, am I obviously talking about v322 and v324?
Where? Can't find them....The spec has been up on the Violectric site for about a week and it is the same output power as the V340.
Before the end of the year if I remember well. Prices not yet fixed but about €2000 and €2400.When are the new releases planned, am I obviously talking about v322 and v324?
Any word on an a DAC in the same series? Might be worth a though if I want to upgrade my V200 at some point...Violectric V101 - About €700 - Most affordable Violectric amplifier - Made in Germany. Pre gain switches are located inside. Amp circuit is G111.
Fegefeuer
- Mar 17, 2011
No DACs for now
Not a DAC at least for the whole next year. There is a possibility for a DAC card for the V324.Any word on an a DAC in the same series? Might be worth a though if I want to upgrade my V200 at some point...
A shame, but thanks a lot to both of you for your answers, appreciate it
Alfredo3001
Violectric dot de > Donwloads > TechGuides (11)Where? Can't find them....
Thank you very muchViolectric dot de > Donwloads > TechGuides (11)
Angel III
If you like a perfect neutral tone and external gain switches, consider the Lehmann Linear. I have the V200 and Lehmann Linear they are two great amps with a slightly different tonality. I hope the V101 has a wider and deeper soundstage because here the G111 mkII falls apart for us audiophiles (certainly excellent for professional use).Gain switches setting inside cool me down. I only owned three headphones, two of them are very easy to drive (TH610, Verisonix N501) the other one needs some power (T60RP). Because of the power gap, I don't want to open the case usually.
lowrider007
Ummmmm, that's V550 pricing, I think that makes my decision a little easier.
Angel III
Do you buy it or leave it in the showcase?Ummmmm, that's V550 pricing, I think that makes my decision a little easier.
