Winamp ASIO contropl Panel help??
Jan 25, 2010 at 1:57 PM Thread Starter Post #1 of 2
rsbrsvp
Hi. I use Winamp and I use the otachan ASIO plug in with ASIO4all driver.
It works fine- but I dont know how to get to the ASIO4all control panel to make some changes.
Under Plugins in Winamp I go to output and select ASIO (otachan) and a window pops up to let me chose buffersize, priority, etc. - but it is not the control panel of ASIO4 all. It seems to be the built in one of the Otachan ASIO interface.
How do I get to the ASIO4 all control panel in winamp?
Also- is USB-ASIO better than ASIO 4all or is it the same sonics?
Thanks for the help.
Jan 25, 2010 at 10:07 PM Post #2 of 2
the Asio4all control panel is not located in Winamp itself but in Windows taskbar (white triangle on green background). The control panel will get activated as soon as you select Asio plugin in Winamp>Preferences>output
