Worth buying OP amps for audio-gd compasS? (sun & moon)?
Jan 3, 2012 at 6:46 PM Thread Starter Post #1 of 3
pHEnomIC
I have an audio-gd compass that i use with some denon d5000's.
I believe it has the earth op amp in it.
I really like this amp and plan on keeping it.  I figure it might be fun to do some customization to it.
Should I buy the opamps?
I was thinking the sun and moon versions.
Also I know they have a v.2 of the sun and moon, any input?
Also, cant these things be used on other amps as well?
Feb 16, 2012 at 12:35 AM Post #2 of 3
FWIW, I have the three op-amps and like the earth one best.  I'm not sure I have the v.2 of the op-amps, though.
[]s
Walfredo
Feb 16, 2012 at 7:20 AM Post #3 of 3
I have Moon and can't find a huge enough difference between it and the stock op-amp. The ACSS connection is slightly better than both. I'd just stick to the ACSS connection, assuming the Compass uses it. i use the NFB 5.
I'd probably get the Earth to keep it as close to ACSS as possible. But frankly, I'd fail blind A/B tests from ACSS to either op-amp.
