xDuoo Link2 Bal Max Now on Apos Audio
Feb 28, 2023 at 9:45 PM Thread Starter Post #1 of 6
Santa Clara, CA
Hi all,
We are excited to share with you that another reliable portable DAC/Amp from xDuoo just got upgraded. Apos now carries the xDuoo Link2 Bal Max Portable Balanced DAC/Amp at the same budget-friendly price.
Its true balance design outputs loads of power while keeping crosstalk and noise as low as a desktop rig. And with a USB-C port, it can be used with tablets, the Steam Deck, and the Nintendo Switch.
Here’s the link to the blog for more information: https://apos.audio/blogs/news/buy-the-xduoo-link2-bal-max-portable-balanced-dac-amp-on-apos-audio
Apos Audio Free Shipping, Lowest Price Guarantee, Apos 2nd Year Warranty and 45-Day Return Policy on all carried products. Check out Apos Ensembles, Apos Specials, and Apos Certified products. Stay updated on Apos Audio at their sponsor profile on Head-Fi.
https://www.facebook.com/aposaudio https://www.instagram.com/aposaudio/ https://apos.audio/ contact@apos.audio
Mar 1, 2023 at 12:20 PM Post #2 of 6
Does it now has independent volume control or still uses the device volume control?
Mar 1, 2023 at 8:35 PM Post #4 of 6
Hi there,
Good question. Yes, it still uses the device's volume control
Mar 1, 2023 at 10:04 PM Post #5 of 6
Is this truly balanced, if the balanced output is not double the SE?
Mar 25, 2023 at 7:27 AM Post #6 of 6
Be aware!
I have problem with my Xduoo link 2 bal MAX
There is some problem with usb C connection either works for a while either not at all.
I try at least 4 different cables besides original same story. You have to push headphone jack and usb C one towards another to get the sound, then run for a few minutes and if you move just a bit it is all over again (static or no sound at all).
The strange part is that the volume button and start/stop button works flawlessly but if you want sound you have to press from both sides.
Don’t know what to do the product is brand new and is like this out of the box.
So QC of Xduoo is obviously miserable never happened to me on Questyle M15 and M12 neither on Hiby FC4
I ask for refund from seller on ali express and wait till 29.03 so will inform you if anybody is interested in this topic anyway.
