Ronnie McCrea
XDUOO Link2 Bal MAX is a new Version of XDUOO Link2 Bal
The primary upgrade the xDuoo Link 2 Bal Max has over the predecessor model is the improved output signal quality. With optimized audio circuitry, Link 2 Bal Max has got an improved signal-to-noise ratio that enhances the output with a cleaner, darker background. The Link 2 Bal Max also has improved crosstalk performance.
xDuoo Link 2 Bal Max achieves an ultra-low distortion of ≤0.001%, a big improvement from the predecessor model.
Parameters
DAC chip: CS43131*2
Input port: Type-C USB
Output port: 3.5mm+4.4mm
Output Power: 3.5mm: 200mW@32ohm 4.4mm: 270mW@32ohm
Sample rate support
PCM: 16-32Bit/44.1-384kHz
DSD: DSD64-256
Frequency response: 20Hz~20kHz(±0.5dB)
THD+N: 0.001 %1kHz (3.5 Headphone AMP)
0.0007%1kHz (4.4 Headphone AMP)
SNR: 124dB (3.5 Headphone AMP)
128dB (4.4 Headphone AMP)
Crosstalk: 3.5 Output:≥79dB
4.4 Output:≥122dB
weight: 28g
Price: 149 USD
https://shenzhenaudio.com/collectio...2-dsd256-usb-dac-balanced-headphone-amplifier
Parameters
DAC chip: CS43131*2
Sample rate support
DSD: DSD64-256
4.4 Output:≥122dB
weight: 28g
Price: 149 USD
