Ben86
- Jun 24, 2015
Anyone installed Ufeel op-amps buffer for your XD05 Pro? Some impressions pls.
I I stalled these on my Aroma Audio A100TB & it's sounds awesome!
With Burson V5iD opamp it's very good sounding.
If you really want to prove a point, try this.
1. Record a video.
2. Set the XD05Pro to EXT + Turbo mode.
3. Power down and fully disconnect the USB-C charger and tester from the XD05Pro.
4. Connect the GaN charger with the tester to the XD05Pro and power it on.
5. Play some sound through the XD05Pro without changing modes.
6. Post the video so we can all see
If this works then like @Ferdinando1968 said may be something has changed in the newer XD05Pro units because on our units this does not work and as he explained it’s how the USB-C handshake works.
OK, so what is the voltage of the charger before connecting to the xd05 pro?Asking me making a "Video prove"? Lol~~ If you don't want to believe it, you don't need to.
Ran the GaN charger test again, the result is the same. As soon as GaN charger was connected to the XD05pro via the usb tester, it automatically recognized or negotiated to 12v even before turn on the XD05Pro. See below pics
(1) before turning the power on
(2) After turning the power on
The usb tester only displays the value when in/out both are connected. Google says GaN usb-c charger (A2743) has a standby power consumption of 0.079w at 220v 50Hz and 0.039w at 110v 60hz.OK, so what is the voltage of the charger before connecting to the xd05 pro?
May we know what has been upgraded please? Using different capacitors?The modified amp module has arrived. There was dead silence! Thanks xduoo!
