itdoessuck
- Feb 1, 2010
Hi,
I have purchased both the Yulong Sabre D18 and DA8; the first through eBay and the second through a distributor. I'm very impressed with the sound quality but both units have not behaved very well. I'm posting this to see if anyone out there has any helpful suggestions / fixes.
The Sabre D18 worked superbly for approximately 3 months, then it started to lose sync with the digital SPDIF and optical inputs - not locking on to the bit stream. This is a well-recognized behaviour; after writing the manufacturer I was told to use a higher quality digital output device. Originally I used an EMU 1212m semi-pro audio card for the output and have tested the D18 with both with S/PDIF and AES/EBU output formats with no joy. I switched to a brand new EMU 1212m card that worked perfectly in another system - same behaviour. I then tried the SPDIF output on my Intel DX58SO motherboard - same behaviour. This is very odd -> the D18 worked without a hitch for three months initially, then didn't work well with three different systems and I'm being told the issue is not with the D18, but with poor quality supply bit streams - from three separate devices. Draw your own conclusions. This is similar to being told that a frog that has no legs can't jump when commanded to because it is deaf.
After spending some frustrating months with the D18 I bought one of the first DA8's to come out. Again, this at first worked perfectly at first with stellar sound. I was very happy - the manufacturer is welcome to quote me on this one if he desires.
After approximately 2-3 months, the unit's LCD display would sporadically start cyclically rebooting when powered on; by this I mean the LCD would first display appropriate data, then go blank, then I’d hear the power relay 'click' and the cycle would repeat. Oddly enough, the DAC would play uninterrupted music during this time. I've tried using different inputs - optical and SPDIF / AES/EBU with no change in behaviour. I'm running a Furman power conditioner in front of the unit to filter the AC line; I tried putting an additional filter in front of the DA8 with no luck. I've written to the seller and haven't received a reply.
The above behaviour is sporadic – some days the DA8 works fine, other days the on-off cycling won’t stop & I just give up, shut it off and switch to the EMU DAC. This makes me wonder about AC line noise issues and that’s why I’ve tried to heavily filter the AC input to the unit to no avail. BTW, none of my other electronic equipment malfunctions during this period.
Other than the above, I think Yulong makes great equipment and I’m obviously a fan. Has anyone had any similar experiences or suggestions?
Many thanks!
