Hello folks. Pls advise which USB-C to USB-C cable to buy so not to have any interference. It needs to be flexible and with angled connecter preferably. Maybe Ugreen? I need it for my DAC.
Low end. Cheap. Generic. Otherwise bang for buck cable thread!
- Thread starter Dsnuts
- Tags
- aliexpress cable
I’d go for these .. Oyaide Neo D+ USB C to C .. great sound quality and sympathetic pricingHello folks. Pls advise which USB-C to USB-C cable to buy so not to have any interference. It needs to be flexible and with angled connecter preferably. Maybe Ugreen? I need it for my DAC.
https://www.musicstore.com/nl_NL/EU...ass-B-1-m-Laenge/art-DJE0007672-000#reviewBar
superuser1
What is the best DIY chin slider solution for cables with wanton chin sliders?
cerbatillo
The first one its better at separation and resolution, the second one its more v shaped, both excellent cables specially if you get deepsnow for 30€ on salesHow does the T-OCC compare to the deepsnow?
Colin5619
Got this Cable today for my KZ AS24 standard version, makes a huge difference in the mids and highs, extremely surprised and content. Got it at a great discount price.
http://Just found this amazing item...ions MK4 F1 https://a.aliexpress.com/_mqYkXp0
Colin5619
Barndoor
http://Just found this amazing item on AliExpress. Check it out! NZ$279.14 40% Off | ivipQ 6 Core Golden Ratio Special Weaving Technology Earphone Cable MMCX 2Pin for N5005 MK4 Legacy2 Blessing3 Variations MK4 F1 https://a.aliexpress.com/_mqYkXp0
For a KZ? Yikes.
"Low end. Cheap. Generic. Otherwise bang for buck cable thread!"
Colin5619
Yes, it was a cheap cable, cheaper than the IEM it’s on. The price was under US$65.
LordZero
- Oct 5, 2007
Anyone know a good/budget ofc+silver plated modular cable? All I find is 50€.
What does the "good" criterion consist of?Anyone know a good/budget ofc+silver plated modular cable? All I find is 50€.
Maybe that
https://a.aliexpress.com/_EzSbtcB
cazador de la bruja
For that money, you will mostly only find no name cables. Simgot LC7 (https://www.linsoul.com/products/simgot-lc7) is the best I can think of, but it's $70. Probably worth it though.Anyone know a good/budget ofc+silver plated modular cable? All I find is 50€.
nihalsharma
Here is my review of Letshuoer LR Nebula Cable.
https://headfonics.com/letshuoer-lr-nebula-review/
The LETSHUOER LR-Nebula stands out as a decent copper cable tailored to enrich the bass and mid-range frequencies. With some IEMs that I paired the cable with, I found the synergy to be quite good, showing the potential performance when upgrading from a stock cable.
PROS
* Decent bass and mid-range coloration
* Lightweight and simplistic design
* Nice packaging and inclusion of case
CONS
- Stiff ear hook
- Does not have modular jack option
PROS
CONS
- Stiff ear hook
Price $165 is not low-endHere is my review of Letshuoer LR Nebula Cable.
PROS
CONS
- Stiff ear hook
nihalsharma
Haha, yes, right. For a cable, it's not low-end (price-wise). Nevertheless, I found it had decent synergy with some IEMs I paired.Price $165 is not low-end
Total: 4 (members: 1, guests: 3)
