Astell&Kern AK380
Jul 17, 2022 at 7:36 AM Post #9,016 of 9,041
Astell&Kern can replace the ak380 battery, but I think the amp battery are no longer available. If your in the US, just drop them an email - it’s @ $70.
thanks!
Your regional AK repair center would be able to replace it. Here in the US it is about $60USD to replace the AK380 battery. Nor sure about the amp battery. The price will vary slightly depending on region.
I don't know who is the main dealer in my country for now, i'm currently in indonesia. might try contacting some old friends.
Aug 15, 2022 at 7:09 AM Post #9,017 of 9,041
guys, is it still(in 2022) worth buying? in below 1000$ price point. *nos open package
Nov 23, 2022 at 1:56 PM Post #9,019 of 9,041
Has anyone here used the ak380 recording kit + mic?
It is the 2500 USD kit.
Is the recording quality from it any good?
Ya . I use the rec kit all the time . Mostly for audience mics at show where I am capturing multitrack feeds from the console. I dont have the DPA mics just the record cradle. DPA are wonderful sounding mics so I'm sure they sound superb.
Nov 30, 2022 at 4:07 PM Post #9,020 of 9,041
So my AK320 stopped reading files off the SD card (Samsung 256) properly. I figured it was just an SD card gone bad, so I purchased a new Sandisk 256gb (formatted to FAT32) and a Sandisk 512gb, all of them say "Damaged SD Card" when inserted. Anyone deal with this before? Seems like it doesn't want to read ANY SD card anymore.
Dec 1, 2022 at 7:29 PM Post #9,021 of 9,041
Did you try formatting the SD card inside the AK380?
Apr 10, 2023 at 11:39 AM Post #9,023 of 9,041
Does anybody knows if there are spare parts available?
I need/want a screw from the back of my amp. The tread of it is bad. Is this still for sale or is there a better solution to keep the 380 and the amp together.
I’m sure I’m not the only one with this problem.
Apr 10, 2023 at 11:52 AM Post #9,024 of 9,041
Possibly; I was able to get the amp replaced because it was faulty about a year or two ago. I'd contact the dealer that sold you the unit, or Astell & Kern directly.
Jul 5, 2023 at 11:33 PM Post #9,026 of 9,041
It's July 2023, can AK still do battery replacement on AK380?
How do you contact AK about battery replacement on AK380?
astellnkern@astellnkern.com ???
I'm in North Carolina, Raleigh area.
I'll also call Moon Audio in Cary tomorrow, and see what they say.
Thanks.
Jul 6, 2023 at 2:08 AM Post #9,027 of 9,041
there are a couple of tiny screws, then a normal suction cup takes the back off - the battery just unplugs - I struggled to find the correct battery for my AK380 and ended up sending it off to AK repair in Germany as it had another issue (was pretty cheap) - they told me they could replace 380 batteries but not amp battery as it was no longer manufactured, though someone on here says it's the same battery, so who knows...
Anyone (successfully) replaced with aftermarket AK380 battery?
If AK380 is going to be powered through USB through its cradle (and always powered off before removing from cradle), then does it still need internal battery for any purpose?
Jul 7, 2023 at 1:34 AM Post #9,028 of 9,041
Yes and yes.
380 battery need to unscrew a few screws. Not as hard as it looks.
Make sure you buy a battery that is the same size as the original. Do not buy one that is smaller. They will advertise the smaller one with higher watts. It's not true. The smaller ones will run out faster.
Jul 7, 2023 at 2:06 AM Post #9,029 of 9,041
Yes and yes.
Thanks.
Any recommendation on a particular aftermarket battery? If you remember which one you bought?
380 battery need to unscrew few screws? What do you mean?
Is the battery held down with screws?
Well, shoot...... :frowning2:
Jul 7, 2023 at 5:26 PM Post #9,030 of 9,041
Thanks.
Just buy from ebay. There isn't a particular brand. Just ask seller for the dimensions of the day battery.
Yes the 380 battery is kept in by a few screws. You need to unscrew then to remove the circuit board to connect the battery. Otherwise you cannot reach the hole to connect the battery.
