Idea: Install HiByMusic app on iBasso DX320, add Tidal, activate PEQ, set parameters.I finally figured out how to equalize. I installed Poweramp Player from the Google Play Store on my iBasso DX320, which comes with many, preconfigured equalization profiles for various headphones, including one for the LCDi4 created by the reviewer Crinnacle, himself. It sounds great, amazing, even. Also, the separate Poweramp Equalizer will grab output from Spotify, so that's also a win. Unfortunately, I haven't yet found a way to equalize streams from Tidal.
Audeze LCD i4 TOTL In-Ear Monitor Discussion
- Thread starter Emerald Core
rebbi
- Apr 11, 2016
Will the HiByMusic app grab and EQ OK Tidal audio?
It will not grab. You can log in to Tidal from the HiByMusic app. Then you can EQ from the app what you play from the Tidal account. No offline mode as far as I know. I do not have Tidal, I use Qobuz. Just tried the HiByMusic app on my android phone. PEQ works on music played from the Qobuz account.Will the HiByMusic app grab and EQ OK Tidal audio?
rebbi
- Apr 11, 2016
Oh, that’s very cool, though. Thank you for making me aware of that possibility! I will report back here.
ozz007
- Mar 2, 2012
You can also used wavelet.Oh, that’s very cool, though. Thank you for making me aware of that possibility! I will report back here.
Wavelet is a wide system eq.
- Mar 12, 2009
Any EQ for iOS for streaming ?
I know, iPhone is not the best platform for a custom EQ
rebbi
- Apr 11, 2016
On another note, does anybody know where you can purchase a balanced cable for the LCDi4?
I really enjoy my lavricable and I've had some made by vikingweave that are outstanding. Stay away from moon cables as they are way to stiff imo.On another note, does anybody know where you can purchase a balanced cable for the LCDi4?
rebbi
- Apr 11, 2016
Hey, thanks so much for that tip! I've never heard of that company. Which series cable do you have... seems they have master, reference, etc...I really enjoy my lavricable and I've had some made by vikingweave that are outstanding. Stay away from moon cables as they are way to stiff imo.
Oh it's the $200 range one if talking lavricable, I bought it awhile back. Viking weave can get pricey but are top notch quality.Hey, thanks so much for that tip! I've never heard of that company. Which series cable do you have... seems they have master, reference, etc...
rebbi
- Apr 11, 2016
Got it, thanks again.Oh it's the $200 range one if talking lavricable, I bought it awhile back. Viking weave can get pricey but are top notch quality.
Full sized headphones are dead to me because of the i4s, they are truly magical. A bit sad that they weren't so popular so we can't expect to get a LCD-i5 anytime soon!I agree completely! I actually just returned a pair of Hifiman Arya Organic full size, open back headphones. Although they are great for what they are, my LCDi4's wipe the floor with them in almost every respect, IMHO. I mean, it's not even close. Fortunately, I was able to pick up an open box, unused pair of LCDi4's from a seller on US Audiomart, at a little over 50% of the retail price. I know it's trite to put it this way, but I literally can't stop listening to them, they are that wonderful.
Grizzleberry
I use a Qudelix-5K for eq'ing my lcdi4. It has built-in PEQ. You can connect via Bluetooth or USB (if your iOS device has USB)Any EQ for iOS for streaming ?
Мне, как обычно, нравится вариант с изголовьем для наушников. Они сидят в ушах под определенным углом, чтобы обеспечить достаточный уровень басов. И поворот головы не влияет на звук. Они ни на миллиметр не смещаются относительно изначально правильного положения в моих ушах.
makan
- Feb 16, 2015
Cool...did you make this yourself? If not, where did you get it?Мне, как обычно, нравится вариант с изголовьем для наушников. Они сидят в ушах под определенным углом, чтобы обеспечить достаточный уровень басов. И поворот головы не влияет на звук. Они ни на миллиметр не смещаются относительно изначально правильного положения в моих ушах.
