This depends heavily on the shape and length of the nozzle, but my favorites are Velvets, Baroque and Spiral Dots FX9, (the older ones). I have many many different tips to test with if problems. Also all Acoustune x07, x08, x70 and variants and copies of these are good to have handyWhich tips have you had the best luck with?
Best IEM tips?
- Thread starter lilboozy
TYATYA
These are graphic of frequency I heard when using samsung phone in this audiotion.Exactly! It was driving me totally nuts to the point where I thought I had a defective right-side IEM. Sometimes it closes off completely, but other times it's just a rolloff in the treble that starts somewhere in the 6k-8k region. It makes things like cymbals, hi-hats, and other sparkly sounds shift to the left side of my head. Very disorienting.
Only solution I've found so far is to try and get a very shallow and loose fit. Not ideal, especially for things like walking which immediately shakes the IEM loose from its very tenuous seal. Sounds like I just need to keep searching for better fitting tips...
It's not quite that. If the seal is especially secure on the right, it's like it gradually keeps suctioning into my ear until the sound closes off entirely either from my ear canal closing or from the tip's bore hole closing (not sure which). But most of the time, even if I have only a moderate seal and moderate insertion depth, I get treble roll off (and only ever on the right side). I can manually push the face plate of the IEM forward (prying open my ear canal front to back) which gives me perfect clarity on that side, but obviously I can't just hold it there all the time. Dunno. It's a puzzle.
Happens with any one of the dozen or more tips I've collected now, including more unusual ones like double-flange tips. And it happens on both my longer nozzle IEM (though not as severely) and my short nozzle IEM.
Ru6 connected to phone and headphone is the RR1 estat.
You can try.
Add Hd800s audition
TYATYA
Samsung phone can compensates FR for each ear after automatic check individual listening ability
Hypops
Seems like a good way to check for hearing imbalances between ears, but I'm hesitant to use those measurements for EQ since you'd be doing so according to "equal volume," which in my experience never sounds quite right. But it does seem like a useful way to check for where and how one's hearing might fall away.Samsung phone can compensates FR for each ear after automatic check individual listening ability
Totally. Was mostly just curious. I've tried all of these except for the Acoustunes. They're on my list now. Next up I've got the three different shapes of Comply foams coming.This depends heavily on the shape and length of the nozzle, but my favorites are Velvets, Baroque and Spiral Dots FX9, (the older ones). I have many many different tips to test with if problems. Also all Acoustune x07, x08, x70 and variants and copies of these are good to have handy
mobbaddict
Not sure but some of them look like Acoustune AET07 and AET16... Some of the Acoustune tips I got with my OG Timeless are really good by the way, sound has more texture then a lot of well known tip brands which often sound plasticky (that includes that JVC Spiral Dots which are overrated IMO). I think it has to do with the stem material which is unusually thick. I have some old Fiio FA1 tips that look similar and that sound extremely good with the Timeless.Does anyone know who makes the fiio hs19 kit ? I can’t imagine fiio made them and figure they must be sourced. I like the foam tips in it and the black and red silicone.
It’s leading me to discover others.
musingclouds
- May 27, 2011
I really like the Eletech Baroques!
https://bloomaudio.com/collections/eartips/products/eletech-baroque-eartips
bru87tr
- May 21, 2016
Yes! I didn’t want to get laughed at, but I love the sound of them. I haven’t found anything that fits and sounds as good.Not sure but some of them look like Acoustune AET07 and AET16... Some of the Acoustune tips I got with my OG Timeless are really good by the way, sound has more texture then a lot of well known tip brands which often sound plasticky. I think it has to do with the stem material which is unusually thick. I have some old Fiio FA1 tips that look similar and that sound extremely good with the Timeless.
TYATYA
Modify ear tip is posible to improve a little. But UAPP does the job well.
Audition with samsung phone to know how your ears perceive the sound then using UAPP to try!
TYATYA
With $5 for this tool, it is cheaper than grap a taxi to go doctor for checking.
My L ear appears not good as the R and listening about 9% less sensitive in comparision
Might want to use spoiler for pics like these.With $5 for this tool, it is cheaper than grap a taxi to go doctor for checking.
bru87tr
- May 21, 2016
lol
helloh3adfi
I don't want to know. I don't want to know. I don't want...With $5 for this tool, it is cheaper than grap a taxi to go doctor for checking.
Hypops
Do others of you find you need more gain/volume with foam tips? I can't tell if foam tips sound more muffled or if it's just a decrease in SPL compared to other tips. Kicking them up like 3-5dB seems to level out most of the perceived differences to other tip types, but I can't tell if that's just my ears falling for the "louder = clearer" trap.
TYATYA
Foam tip for mids.Do others of you find you need more gain/volume with foam tips? I can't tell if foam tips sound more muffled or if it's just a decrease in SPL compared to other tips. Kicking them up like 3-5dB seems to level out most of the perceived differences to other tip types, but I can't tell if that's just my ears falling for the "louder = clearer" trap.
When need highs, silicon/rubber may be suitable.
I tend to crank up volume when lacking/reduction of highs and/or low.
Do you?
Hypops
I guess that's why I was asking. For me, I can't quite tell if foam tips are damping only certain frequencies or if they are simply quieter across the entire spectrum (compared to silicone tips).Foam tip for mids.
Do you?
Total: 8 (members: 0, guests: 8)
