AussieMick
I bought the pair to do exactly that. Flawless via Ethernet.Any thoughts on 2Go+2Yu as a Roon endpoint in terms of stability and overall performance (with an internet connection via Ethernet)?
Thanks!
Thanks!
I use them via WiFi and I've never, ever had any issues! Highly recommended.Any thoughts on 2Go+2Yu as a Roon endpoint in terms of stability and overall performance (with an internet connection via Ethernet)?
Thanks!
The current fw is 1.6.1. Not sure why it's saying no update available. Have you tried doing a factory reset?Hey folks, recently got a new 2Go and Hugo 2- firmware is at 1.5.6 and the unit is not finding that there is an update available.
Status in Roon is currently showing as uncertified. Any tips?
I can only think of 2 possible avenues. Go to a different location and use their WiFi to see if that makes a difference. Or contact Chord Support, they may have a way to force the update down to your IP.Yes, already done. Seems stuck on 1.5.6 even after a factory reset…
Connect to your phones hotspot and see if it reports the update. Some ISP's and some firewalls will block downloads mistaking it for a torrent siteYes, already done. Seems stuck on 1.5.6 even after a factory reset…
Thanks for the suggestion, didn’t work either.Connect to your phones hotspot and see if it reports the update. Some ISP's and some firewalls will block downloads mistaking it for a torrent site
if the spaghetti code (as you call it) was made in Italy, it would be the best code in the worldEven if the firmware upgrade becomes avaiable again, have fun trying to install it. After completing the entire upgrade progress, it still says 1.6.0.
I'm waiting for 1.6.2 for this reason as I got better things to do then to deal with Chord their spagetti code.
The Poly has the same firmware upgrade problems.
