We are very glad to introduce the all-new DEVA Pro with the Bluemini R2R! The new DEVA Pro (SRP: $329) picks up where its predecessor left off, offering full-range, audiophile-grade sonics, whether listening via wired or via Bluetooth. The new model builds on the value of the original by incorporating two recent HIFIMAN developments --Stealth Magnet technology and the Himalaya R2R DAC (digital to analog) architecture.
Stealth Magnets feature a unique shape that enables waves to pass between the magnets without generating interference. Sonics are detailed and transparent, exposing every detail of the recording. Benefiting from the Stealth Magnets design, the Deva Pro enhances body, clarifying imaging and further improving the soundstage.
Packaged with the DEVA Pro is an update to the original Bluemini that enhances detail and overall performance through the company’s HIMALAYA DAC, which features the R2R architecture. A chip composed of an array of resistors with a new algorithm reduces power handling between the chip and peripheral components. As a result, signal-to-noise ratio, total harmonic distortion, and energy consumption are at their most efficient and cost-effective.
Different from DEVA, the DEVA Pro has dual-sided 3.5mm sockets on the earcups, which means that the headphones would be compatible with a dual-sided 3.5mm TRS cable. In addition, the socket on the left eacup is designed to be compatible with the Bluemini R2R or a single 3.5mm TRRS cable.
Specifications:
Frequency Response: 20Hz-20KHz
Impedance: 18Ω
Sensitivity: 93.5dB
Weight: 360g
The DEVA Pro will be available in October 2021. You can find them from our authorized dealers or our official online store.
https://hifiman.com/dealers
https://store.hifiman.com/
