YesMaam1111
Heyyy I read this and had to comment because I too experience itchy, wet ears. I kinda already figured out what was wrong on my own, but got confirmation from an ENT. I was diagnosed with having eczema INSIDE my ears Idk how the heck thats even possible My symptoms were similar as if I had eczema somewhere else on my body. if I try to use earbuds especially apple iphone buds.. My ears immediately react and itch and begin oozing a ear wax type fluid. I suppose my ears are not friendly with earbud materials that have direct contact to my canal. Now, whenever I eat things that make my mouth water.. Like starburst or anything juicy... Yup.. you guessed it.. my ears will drain that earwax fluid again. The feeling of the wax fluid oozing in my canal causes the itching sensation. I constantly keep them dry by swirling a Q-tip when I can. And when I do.. my Q-tip is always wet!! I also noticed somtimes when smoking, my ears react again and ooze a little. Which makes me think the smoke is also a allergen to my ears. Basically my ENT prescribed me some eardrops called CIPRODEX and it WORKS!!!!!!!!!!!!!!!!! Please ask for this ear drop. It keeps your ears from becoming inflammed. Its like liquid gold. If you continue to use as you should your ears will be less itchy and will become less flaky from not itching and scratching down those canals. I hope my comment helps someone cause this sucks!!!
