Erzetich Charybdis
Apr 19, 2024 at 5:08 PM Post #226 of 274
I was wondering if there are also separate pads available for the Erzetich Charybdis with an audible improvement.
not that the current pads are bad, but an adjustment by, for example, curved pads might really improve the signal flow
There are, not curved pads but Velours and Leather (standard)
https://shop.erzetich-audio.com/index.php?route=product/product&product_id=108&search=Pad
https://shop.erzetich-audio.com/index.php?route=product/product&product_id=107&search=Pad
Apr 19, 2024 at 6:07 PM Post #227 of 274
The pads used in Charybdis are 110mm diameter (I asked the mfr). That means any number of aftermarket pads can be used. However, pad rolling outside the manufacturer's product set is risky ... those of us who pad roll much find this out the hard way. The farther one diverges (in choice of aftermarket pads) from the mfr's stock pad design, the more potential for sonic chaos there is.
The stock pads appear to be non-perforated, non-angled, and relatively deep (I'm guessing ~1 1/8" to 1 1/4" deep). So if I owned this headphone and was trying to pad roll it, I'd probably start with something like:
  • Brainwavz XL suedes, just to see if a different pad material made a positive change
  • One of Dekoni's angled sheepskin pads, just to see if even a slight degree of angling helps or hurts the sound
  • One of Dekoni's angled velour pads, dimensions of which are identical to the angled sheepskins (I bought a pair of these for my Caldera. They're physically beautiful, well made pads):
  • Then getting more adventurous, I'd try the Caldera Lambskin Thicks--adventurous because these are perforated:
(the 2nd listed pad option would probably be the what I tried first w/the Charybdis)
One of the unknowns here concerns the interior foam. This can have quite an effect on sound, too, but I have no idea how any of the pads linked above compare to the foam in the Charybdis' stock pads.
Apr 20, 2024 at 4:57 PM Post #228 of 274
De pads die in Charybdis worden gebruikt, hebben een diameter van 110 mm (ik heb het aan de fabrikant gevraagd). Dat betekent dat een willekeurig aantal aftermarket-pads kan worden gebruikt. Padrollen buiten de productset van de fabrikant is echter riskant... degenen onder ons die veel padrollen, komen hier op de harde manier achter. Hoe verder men afwijkt (in de keuze van aftermarket-pads) van het standaardpadontwerp van de fabrikant, hoe groter de kans op sonische chaos.
De standaard pads lijken niet-geperforeerd, niet-hoekig en relatief diep te zijn (ik vermoed ~ 1 1/8 "tot 1 1/4" diep). Dus als ik deze hoofdtelefoon zou bezitten en hem zou proberen op te rollen, zou ik waarschijnlijk beginnen met zoiets als:
  • Brainwavz XL suède , gewoon om te zien of een ander zeemmateriaal een positieve verandering teweegbracht
  • Een van Dekoni's schuine schapenvachtpads, gewoon om te zien of zelfs maar een kleine mate van kantelen het geluid helpt of schaadt
  • Een van Dekoni's schuine velours kussentjes , waarvan de afmetingen identiek zijn aan de schuine schapenvachten (ik heb er een paar gekocht voor mijn Caldera. Het zijn fysiek mooie, goed gemaakte kussentjes):
  • Om dan avontuurlijker te worden, zou ik de Caldera Lambskin Thicks proberen - avontuurlijk omdat deze geperforeerd zijn:
(de tweede vermelde padoptie zou waarschijnlijk degene zijn die ik als eerste probeerde met de Charybdis)
Een van de onbekenden hier betreft het binnenschuim. Dit kan ook een behoorlijk effect hebben op het geluid, maar ik heb geen idee hoe een van de hierboven gekoppelde pads zich verhoudt tot het schuim in de standaardpads van Charybdis.
May 1, 2024 at 7:15 PM Post #231 of 274
I tried the Charybdis with a Viva tube amp at a show and was impressed by it. One of the best TOTL headphone, arguably better than the Susvara and many others. Spacious sound, all the frequencies are well done and indeed with a good bass.
Without the price factor I would get one in a blink.
Possibly the best Planar going around at the moment.
May 1, 2024 at 7:34 PM Post #232 of 274
I love the Charybdis but find it tough to use with a powerful amp because it is so efficient so I tend to use it with the chord dave direct...on a relative basis in the world of TOTL HP's it is a veritable bargain
May 1, 2024 at 10:17 PM Post #233 of 274
Could you please share what you mean by 'tough to use with a powerful amp'? Sound doesn't feel right with more powerful amps? I recently upgraded from wooaudio wa8 portable setup to a desktop setup of Weiss dac plus cayin ha300 (with elrog tubes), and I felt the headphones scaled beautifully with this setup. Blaz himself sells a very powerful amp (Scylla) as his recommendation for Charybdis.
May 1, 2024 at 11:21 PM Post #234 of 274
I have a chord dave/blu2 and feliks envy...as I said the Charybdis is incredibly efficient and thus I have to use it on low gain otherwise it is simply too powerful for the HP..the dave works quite well by itself
May 2, 2024 at 5:00 AM Post #235 of 274
Enjoying them a lot on MDave.
May 2, 2024 at 4:33 PM Post #236 of 274
they pair extremely well with the dave IMHO
May 2, 2024 at 4:38 PM Post #237 of 274
May 2, 2024 at 5:33 PM Post #238 of 274
to my ears the envy requires low gain which to me kind of negates the positives of the envy...using it on low gain I still had to be at -30 on the dave volume....with the dave it just seems not better but more comfortable to use
May 2, 2024 at 5:47 PM Post #239 of 274
I'm afraid I don't follow.
Is your only positive more power/volume?
What about the tube flavor?
May 2, 2024 at 7:11 PM Post #240 of 274
my point is the envy to my ears sounds better on the mid or high gain and with the charybdis I can only use it on low gain
