[FiiO LC-RE/LC-RE Pro/LC-RE Pro 2022] MMCX cable Gold-Silver-Copper swappable plug Earphone Cable
Apr 24, 2020 at 6:17 AM Thread Starter Post #1 of 199
FiiO
Sponsor: FiiO
Guangzhou,China
Flagship material- gold, silver and copper braided in one cable——LC-RE Pro swappable plug headphone cable
The upgraded LC-RE Pro consists of three kinds of wires – Furukawa monocrystalline copper, gold-plated monocrystalline copper, and pure silver. All three kinds of wires go through ultra-high temperature continuous casting after secondary smelting to be of the highest quality. As a flagship-grade braided headphone cable, the LC-RE Pro settles a matter at one go.
The LC-RE Pro is always treated as a flagship earphone cable, which consists of 20 gold-plated + 20 pure silver + 20 monocrystalline copper wires. 4 strands in a total of 240 wires achieve better conductivity that presents rich musical details.
In addition, it features twist-lock interchange audio plugs, allowing you to freely switch between 3.5mm single-ended/2.5mm balanced/4.4mm balanced plugs depending on your source.
Specially designed for comfortable wearing experience
To provide a better user experience, we stick to making optimization in every detail. Both the LC-RD and LC-RE Pro are designed with expanded MMCX connectors for reliable connections, and the ergonomic angle makes for a more comfortable wearing experience. Meanwhile, we carefully selected medical-grade stainless steel 316L material for the audio plugs. We care more about comfortability and durability even though the processing is more difficult and the cost is increased. Every choice is for those who are in love with music.
*The LC-RD is available on our AliExpress Official Store. Click the link below to take it home right away.
https://www.aliexpress.com/item/32896656764.html
*The LC-RE Pro is available on our AliExpress Official Store. Click the link below to take it home right away.
https://www.aliexpress.com/item/4000971898372.html
Apr 24, 2020 at 11:24 AM Post #2 of 199
I've noticed this quite some time ago, finally is official
Apr 26, 2020 at 4:43 AM Post #5 of 199
Apr 28, 2020 at 6:11 AM Post #6 of 199
Any idea when it will be available in North America (Amazon etc) ? Thanks!
Hi,
Affected by covid-19, we could not send goods to Amazon now. You could consider whether purchasing one from Aliexpress?
Best regards
Apr 28, 2020 at 8:21 AM Post #7 of 199
Hi,
Best regards
Understandable. Thanks for letting me know. Excited to get my hands on one!
Apr 29, 2020 at 10:56 PM Post #9 of 199
Would these work with my older Shure 846 iem,'s? Thanks for any help. Sorry for my lack of experience.
Hi,
Yes, the MMCX version is compatible with the Shure 846.
Best regards
May 2, 2020 at 9:17 AM Post #11 of 199
Ordered in 0.78mm
Only 5 left :wink:
May 2, 2020 at 10:30 AM Post #13 of 199
From THIS PAGE
"While the LCDi4 and iSINE's two-pin connectors aren't proprietary and many standard ones will work, we did throw in a small twist that's important to note:
You'll notice a groove on the connector of the cable (under the L and R on the iSINE cable), and a corresponding tab inside the headphone connector. This is to ensure correct polarity. When using any aftermarket connector/cable, it's important to make sure the connector fits within this tab so it doesn't damage the connector inside the headphones, as this would not be covered by warranty. The recommended dimensions for connectors without this groove is 2.5mm x 5mm, and the pins are .75mm in diameter, but .78mm will also work."
The connectors FiiO uses have the groove, so it'll be fine.
May 5, 2020 at 6:11 AM Post #14 of 199
From THIS PAGE
Thanks so much!
