[FiiO UTWS1] True Wireless Bluetooth Module,Giving your earphones a new voice, MMCX/0.78 2pin
Dec 25, 2019 at 4:24 AM Thread Starter Post #1 of 107
FiiO
Sponsor: FiiO
Guangzhou,China
FiiO UTWS1 will be your best choice to connect earphones, and turn them into a high-fidelity, true wireless set. It adopts the new Oualcomm QCC3020 supporting Bluetooth 5.0 and TWS+, as well as aptX/AAC/SBC. It also supports Intelligent DSP noise cancellation and daily life waterproof. What's more, it is available in either 0.78mm 2-pin connector or extended MMCX connector, allowing a great variety of earphones to be reborn as true wireless buds.
Key features of the FiiO UTWS1:
  • Supports extended MMCX/0.78mm 2-pin connectors
  • FPC Bluetooth antenna
  • Intelligent DSP noise cancellation
  • Adopts Qualcomm QCC3020
  • Supports Bluetooth 5.0
  • aptX/AAC/SBCB Bluetooth codecs support
To find out more about the UTWS1, please visit the product page: https://fiio.com/utws1.
If you are interested in getting one, check with our respective local sales agent (https://www.fiio.com/wheretobuy) for its availability or grab one from FiiO Aliexpress store: https://www.aliexpress.com/item/4000406202267.html.
Best Regards
FiiO Electronics Technology Co., Ltd
Dec 28, 2019 at 10:10 AM Post #9 of 107
Having already bought TRN BT20S (and ending up discarding it due to noise flooer) and BT20 (less noise floor but I suspect it does not support the independent connection for left and right earpiece), I'm not going to buy a third version of the same product. The noise floor on BT20S is simply unacceptable with my CIEMs (116db sensitivity) and the fact that this uses the same chip is really discouraging.
I hope in the future a new chip will come out, allowing this form factor to shine as it deserves. I find it absolutely perfect for custom in-ear monitors.
How is the volume going to be controlled with these (I remember reading that was one of the improvements over BT20S)?
Edit: if, on the other hand, the "Optimized output LRC network" that's described on the product page brings the noise floor on the same level as BT20, I might seriously consider buying these.
Jan 5, 2020 at 5:54 AM Post #13 of 107
@FiiO any idea on when the two pins version is going to be available in Europe?
Jan 7, 2020 at 5:48 PM Post #14 of 107
I see the 2pin version was silently added to listings on their AliExpress store. (it wasn't before)
I already ordered myself one on Jan 2nd.
Jan 10, 2020 at 3:39 AM Post #15 of 107
Dear user,
The sellers in Europe do not have the 2pin UTWS1 in stock currently. We do not have the estimated available time currently. You could consider getting one in the Aliexpress instead.
Best regards
