Hiby R6 Pro II (2023 Edition) - Launch, Hype, Thoughts & More
May 18, 2024 at 4:28 AM Post #1,966 of 1,979
I have asked headquarters to take down all mention of Airplay in their Android device pages. They also thought it was supported by apps on the Play Store but users' experience tell otherwise.
The non-Android players (R3 etc.) do have built-in airplay rendering support.
Hopefully this was not a major factor in your purchase decision. If it was, do email hello@hiby.com and we will discuss options with you.
May 18, 2024 at 7:45 AM Post #1,967 of 1,979
I think you are doing the right thing here (and I appreciate the transparency). There are ways to get Airplay on Android (helper apps, etc.) but most aren't worth the effort and frustration for the result.
May 18, 2024 at 9:58 AM Post #1,968 of 1,979
am all ears for what you think is the best set of apps for this, even if we are taking down the word Airplay.
May 18, 2024 at 10:22 AM Post #1,969 of 1,979
Airmusic is probably the best for Android 10+ or rooted devices. It's not free, but does have a trial version to test with. Another option is AirConnect (a helper app) that converts to UPnP or Chromecast but has to run on a PC on the same network. Both options can be tricky to set up. Note these are audio only solutions.
May 19, 2024 at 12:35 AM Post #1,970 of 1,979
Thank you
May 27, 2024 at 3:41 AM Post #1,972 of 1,979
This is an odd one:
if I turn my DAP off, the next time I restart it, it won't be able to connect to my internet unless I restart router - as otherwise DAP cycles through 3 states:
  1. disconnected
  2. connected but on 2.5ghz
  3. connected on 5ghz but soon goto 1 again
sitting next to router when it reconnects seems to fix it. Its normally fine once its connected.
Router is a TP Link VX220-G2V AX1500 Wireless Gigabit VoIP VDSL Modem router(I assumed someone would ask)
Nothing else in house has this problem. I can connect phone but not router, from anywhere in my house.
I normally leave it on, I just turned it off to save power. Now I see why I leave it on.
May 28, 2024 at 4:05 AM Post #1,973 of 1,979
This is an odd one:
  1. disconnected
Seems like a WiFi range issue. DAPs have lesser range compared to phones due to extra shielding to avoid noise etc. Although in my experience the Hiby R6P2 has decent range, I don’t have to sit next to my router.
You can try the following.
- In your router, separate the 2.4ghz and 5ghz into two separate SSIDs with different names (it will appear as 2 different access points for devices). Now connect your DAP to the 2.4ghz SSID. 2.4ghz has longer range compared to the 5ghz and works better through walls and other obstacles.
May 28, 2024 at 4:14 AM Post #1,974 of 1,979
This is an odd one:
  1. disconnected
I had exactly the same problem at home with a repeater, no problem when I tested the dap in my parents'home. I change my repeater and use now a Wi-Fi mesh. No problem anymore.
May 29, 2024 at 2:09 PM Post #1,976 of 1,979
hi....so i got this r6p2 with good deal & still long warranty weeks ago
but got some question, so i tried the drx10k plug in, but why the sound often kinda become not stable? for example the vocal become too forward for 1-2 sec... then 10 sec later the bass punch become harder, etc
so far, drx10k is the plug in i only install, and try to change its setting but still the same .... am i doing something wrong?
also how long does it usually take for the battery to empty if u not using it?
its been a while since i own DAP, but the battery kinda drain out faster compare tablet/phone when in idle (im using airplane mode & normal cpu setting thing in dev mode)
May 29, 2024 at 7:40 PM Post #1,977 of 1,979
What are your settings in the DRX10K plugin? You can tap on the name of the plugin to configure it.
Bass dynamics 0 mids dynamics 0 treble dynamics 0 would give a bypass effect (no effect), however the default is 0.7 0 0.4 for some effect in bass and treble dynamics.
The gain I advise to leave at -6.0 (negative 6) as standard, to give headroom for the plugin to work, especially if any of the dynamics sliders are at positive values.
May 30, 2024 at 3:46 PM Post #1,978 of 1,979
i also left it on default setting or bass at 0.5 and the rest at default .... try many setting but mostly always end up at that setting again
but actually somehow its works fine again after i reset factory ... i guess i messed up somewhere?
May 31, 2024 at 3:31 PM Post #1,979 of 1,979
Hey @Joe Bloggs feature request for the plugins, could the values be moved above the sliders or plus and minus buttons be added to the ends? When sliding the slider finger blocks the values unless you hold device in a really awkward way!
