HIFIMAN New Desktop DAC/Amps: EF500 and EF499!
May 1, 2024 at 5:37 AM Post #136 of 154
So the reason Qobuz windows app wont work is Qobuz still hasn't released Qobuz connect. However you can use qobuz through other apps such as Audirvana which does have this feature and you can run, use and stream qobuz (as well as other streaming services) through that, which Im now doing and works well
May 10, 2024 at 9:30 PM Post #139 of 154
I have an EF600 right now along with a Singzer SA-1 and Schiit Midgard. Guess I'm trying to find my "end game" solid state amp. Would the EF499 or 500 be any sort of downgrade from the EF600?
May 10, 2024 at 11:09 PM Post #140 of 154
EF499 would definitely be a downgrade. I’m less sure of the differences between 500 and 600
May 10, 2024 at 11:17 PM Post #141 of 154
Could you explain a bit why you'd want to get EF499 or EF500? As in what did you not like about EF600?
Also from previous comments in this thread, sounds like if you're running dac only then EF400 and EF500 are practically the same (difference is EF500 has better internal amp), not sure about EF600 though.
May 11, 2024 at 11:07 PM Post #142 of 154
out of topic - Hi I have SA-1 too, how is it pairing with EF600?
May 11, 2024 at 11:17 PM Post #143 of 154
It was a fine pairing. I didn't notice a difference in sound compared with my Bifrost 2 though.
Jun 1, 2024 at 9:50 PM Post #145 of 154
I just got the EF500 today.
It seems to have the same channel imbalance issue with the volume wheel that was documented by users of the EF400. Apparently, it balances out around the 8 o'clock point, but it gets too loud for my ears before I reach the 8 o'clock point, and so I have to lower the source volume (my phone) by a couple button presses. Does this degrade the sound quality?
I'm using the HE1000SE and some IEMs.
Jun 1, 2024 at 9:58 PM Post #146 of 154
I just got the ef499 myself and I don't have this problem with iems or anything else for that matter. I'm assuming you're using low gain? I can say it is pretty loud with my iems even barely turned to 7:30. Perhaps it's a problem with the Himalaya ladder couldn't say. But with the ef499 I have no problems (Phillips r2r dac)
Jun 1, 2024 at 10:17 PM Post #147 of 154
Ah, I see, yes, I'm on low gain. From what I understand, an R2R volume wheel is supposed to get rid of channel imbalance. But I'm not sure if this is an R2R volume wheel on the EF500. The Topping L70 has an R2R volume wheel, and it makes clicking noises, and with each click, the volume goes up in small increments. The volume wheel for the EF500 just turns smoothly, and it gets loud really fast. I wish the channel imbalance would resolve before it got too loud for my ears.
Jun 2, 2024 at 12:50 AM Post #148 of 154
I think you're thinking digital volume knob vs analogue volume knob.
And yes digital volume knob would generally have perfect matching volume between left and right channel at any volume.
While most analogue volume knob would have imbalance at really low levels.
Though feel wise I still like analogue volume knob better also it's a bit more predictable, since all the way left is off all the way right is max, so you can roughly know how much to turn to get to the exact volume you want.
Jun 2, 2024 at 8:07 AM Post #150 of 154
Interesting, apperently its best to turn on the EF500 for around 10min before playing. Didnt know that just turning it on any playing has quite abit of audable distortion but it goes away as it warms up.
I think in general for R2R it's best to leave it on 24-7, but in this case since it's tied to an amp so people probably don't want to leave it on all the time.
Or maybe they still could? Not too sure.
But I guess having a bit of warm up time is like the middle ground lol.
