- Mar 20, 2013
Right'o Captain Obvious but talking about music is like dancing about architecture
...and ?
Stay updated on iFi audio at their sponsor profile on Head-Fi.
Right'o Captain Obvious but talking about music is like dancing about architecture anyhow and I bet the sonic improvements of XE USB + USB Enhancer would be impossible to measure, so at the end of the day there really is only one way to find out. Been listening to Morricone for decades for that matter.
Upgrading power supply on computer makes wonders…Finally found a used JCAT XE USB and it is on the way. Will do a comparison vs the matrix element H and post here with my findings.
I'm using a Corsair RM750. Do you think there would be much difference? My power consumption is always low.Upgrading power supply on computer makes wonders…
Make that thing the next if you dont have one with good measurements. Ripple/Transients
Corsair AX1600i will make you doubt Audiophile PCIe card
I second the titanium power supply upgrade.I'm using a Corsair RM750. Do you think there would be much difference? My power consumption is always low.
There are non titaniums that have better ripple and transients.I second the titanium power supply upgrade.
It made a noticeable difference in my system as well.
Not huge but its noticeable.
Well, there are other criteria that affect the sound, theres incoming rush, better quality caps and other factors as well.There are non titaniums that have better ripple and transients.
So it depends on which Titanium you bought.
Also AX1600i is the only one GaN transistors
Does anybody know the USB power output specs?
5V and 900mA?
I can not seem to find it anywhere for JCAT USB XE.
