invo
- Feb 10, 2015
Soundwise ?
Had the octave mkII now have the menuet and did compare it to the musette. For me the Menuet gives me what i was looking for in
Naturalnes, flow and detail retrieval.
Musette is a little more laid back, more calm and some "thickeness" can be heard sometimes but only when a/b with menuet.
This has been said many times but it is true that the musette has similar sound signature but musette brings that extra energie and extention.
This is when using BNC input .
Pavane might get you that %10 more when used in balance mode
But the rest of your set up has to be up to the task too
In my situation the menuet had the perfect balance price/sound ratio
Using with speakers no headphones
Thx.
Have u compared it to ygg? I think those two are competitors at the same price..
Thx.
Thank you for your input.
I am just concerned that the sound will be too smooth. I prefer a little sparkle on the top frequency.
too smooth that's is subjective to the listener
you are right some may find NOS dac too smooth but the Menuet is one of the least ''smooth'' nos dac's that i have heard or owned.
At the end, i chose other sound attributes instead of sparkle, but i know what you mean
i am using silver Ic and i think it blends well
I compared it with the Yggdrasil, before choosing the Menuet. The choice was not easy because they are probably the best dac in this price range.
I found the Yggdrasil more sibilant (bright?) and forward.
The Menuet is more natural, deep and warm.
For my system it is the perfect match.
But you cannot go wrong with these 2 dacs
@invo
Where did you buy the Menute in Canada?
I am in BC order it from Atelier-Audio in MTL !
Are you interested in One ?
