bru87tr
- May 21, 2016
I recently got a set of the older KZ PR1, man for cheap IEM these are smooth and very nice sounding.
They need to be upgraded. It's done like this. You need to use a thin sewing needle to remove the metal mesh at the outlet of the channel and carefully remove the foam plug inside. Do the same on the second earphone. After this cork removal procedure, you will not recognize them. A nice sound will appear. Excellent highs will appear and the bass will be a little different, but better. Try it, the process is reversible, and if anything happens, the foam rubber plug can always be inserted back. And the mesh is kept on a sticky layer, the main thing is not to get it dirty. I have an LS15 and an LS Cadenza 4, but the Cadenza 4 is not a planar. I strongly recommend listening to Simphonio PB10 - these are planars with the addition of one armature driver, which compensates for almost all the shortcomings of planars.The Letshuoer S15 is one of the warmer planar IEMs with a very smooth treble and thicker note weight.
I love my KZ PR1 Pro although I don't own any other planar IEMs. I love my Monoprice Monolith M1060s and for an IEM, I do find the PR1 Pro to be quite balanced across the frequency range: fast transients; tight bass and rumble without bleeding; detailed mids and sparkly highs (not over the top and sibilant though). If this helps.
I think campfire supermoon is the only planar CIEM on the market. The universal version sounds quite good.Hey planarheads!
May I know what's your suggestion for planar ciem if you have or know one that would work ..i'm coming from lcdx & klanar and both are fantastic tools for mixing so I'm looking at what could be a perfect planar ciem addition.
Akoustyx S6 I use seems like it has a lot of bass from the graphs, but it actually feels very lean on it until you EQ that in. Also, perfect IEM for EQ-ing.Is there any planar IEM with a flat bass profile and neutral target curve? I find it funny that almost all planar headphones have a flat bass but in the IEM world a minimum 5db boost has become the standard for everyone. I don't mind a slightly boosted bass but I think it's a bit too much if I compare the OG Timeless with the flatter Hifiman RE400. Would love to have a planar equivalent of RE400 or ER2.
Yes that was my understanding as well based on these different Harman target curves:But isn't a rising bass profile or an outright shelf necessary to replicate the subjective experience of the flat looking bass on headphone graphs in IEMs? That was my impression so far while being in this community and learning stuff. And a Sennheiser engineer said the same thing too in a podcast, describing the bass in their IE line. Hence the different tuning profiles - on paper. Or do you really find e.g. a 5 dB bass shelf rising from 200 Hz unnatural? I agree with you though, the Timeless is V-shaped, so, by definition, unnatural sounding.
In any case, check out what people say about the TinHifi P1 and Plus and the Sivga Nightingale.
No matter now much your own tastes match the harman target, there is indeed a +4db shelf on the in-ear target versus over-ear. I'm not sure about the technical explanation for that but it does correlate with the comment from the Sennheiser engineer that you mentioned.
I haven't heard any Etymotic so I won't comment on pure flat bass for IEMs but let's say there might be a compromise to find in between both curves.
Thanks for posting these curves. I also have no clue why our ears behave so, it would be a great topic for @Resolve and the Headphone show to explore if they haven't yet.
By the way, here's the podcast (50:10) where the Sennheiser product manager describes bass and treble, implying that the IE900's bass is "neutral."
Also, the GoldPlanar GL12 also measures quite flat, maybe that could also interest you.
I have the Tanchjim Ola, and that's flat as well with a serious sub-bass roll-off, and it's fine for a lot of genres (it was my office beater set) but it can't match the natural and versatile, all-rounder sound of the Studio4, for example; I found that flat bass is just not enjoyable, and a I'm a far cry from a basshead. It's a loss of information.
Stay updated on headphones.com at their sponsor profile on Head-Fi.
