my audeze lcd-2closed 60ohms 101db works very well even from 3.5mm output,just waiting balanced 4.4mm cable to arrive to work far better on my FIIO Q3 MQA. balanced output 330mw and audeze needs 100-250mw sourse. now think i need desctop dac/amp for lcd-2c closed or not?150ohm, 104db/mW sensitivity
Portable DAC and Amplifier Q3 MQA Edition Is Officially Released!
- Home
- Forums
- Head-Fi Special Forums
- Premier Sponsor Forums and Sponsor Forums
- FiiO
- Thread starter FiiO
- Tags
- fiio fiio q3 fiio q3 mqa mqa
Dust by Monday
Maybe my hearing just isn't good. I plugged my IE 400 Pro IEMs into the Q3 and turned the volume up to 100% on high gain with nothing playing and I couldn't hear any hissing.
Also, using my HD 660s in my Q3 on low or high gain doesn't sound any different than the $9 Apple dongle out of my iPhone. I do like the premium feel of the Q3 with the volume knob though, so there's that, however, if I wanna be on the go, I'll just plug into the Apple dongle.
somethink wrong with your equipment but Q3 is lower output power vs Q3 MQA. im connected my lcd-2c cb to fiio Q3 MQA and at low gain volume up at 100% way too big sound for my ears. comfortable is 70% of volume. and thats from 3.5mm output 170mW, balanced will be 330mW and lined up to usb-c gives 370mW !!! Fiio Q3 MQA is animal for 110gr weightMaybe my hearing just isn't good. I plugged my IE 400 Pro IEMs into the Q3 and turned the volume up to 100% on high gain with nothing playing and I couldn't hear any hissing.
Dust by Monday
I listen at less than 50% volume, I was just testing the noise floor but couldn’t hear any hiss even on high gain with sensitive IEMs.somethink wrong with your equipment but Q3 is lower output power vs Q3 MQA. im connected my lcd-2c cb to fiio Q3 MQA and at low gain volume up at 100% way too big sound for my ears. comfortable is 70% of volume. and thats from 3.5mm output 170mW, balanced will be 330mW and lined up to usb-c gives 370mW !!! Fiio Q3 MQA is animal for 110gr weight
no hiss,it has newest xmos xu316 chip. if you want hiss must buy full tube AMPI listen at less than 50% volume, I was just testing the noise floor but couldn’t hear any hiss even on high gain with sensitive IEMs.
Dust by Monday
I don't want hiss hah. I just figured there'd be some sort of noise floor with sensitive IEMs.no hiss,it has newest xmos xu316 chip. if you want hiss must buy full tube AMP
ears dont hear any floor noise, they measure with technical equipment.I don't want hiss hah. I just figured there'd be some sort of noise floor with sensitive IEMs.
do i feel difference upgrade from Q3 MQA to Q7 for audeze lcd-2c closed back?
Dust by Monday
Sometimes my Q3 goes mute randomly and I have to turn it on and off a few times to get the sound to come back. This is connected to a Mac. Anyone else?
my Q3 MQA too. this happened once for month use.acer predator laptop. i think small problem . upgraded to xduoo ta-22 desktop now. so fiio Q3 MQA on sale.Sometimes my Q3 goes mute randomly and I have to turn it on and off a few times to get the sound to come back. This is connected to a Mac. Anyone else?
kgs51
- Oct 30, 2015
kgs51
- Oct 30, 2015
Can this amp drive 300ohm headphones in balanced mode?
If not can someone recommend a good amp that could?
Dear friend,Can this amp drive 300ohm headphones in balanced mode?
The output power of Q3MQA is 40mW(300Ω,THD+N<1%). And due to individual preferences, you could read the professional reviews and comparisons, as well as try out by yourself.
Best regards
try fiio Q7 for 300om cans.Can this amp drive 300ohm headphones in balanced mode?
Honestly, the first version helped shunt me into this hi-fi world. Good company, good product for people looking to test the waters.
- Home
- Forums
- FiiO
