equalspeace
Headphone Modder (Link)
- Aug 12, 2016
So this new 620s is tuned to be a 600 w bass in a close back version at a lower impedance?
The new ones sound good, but I really don't like how they feel. Both too stiff and too soft at the same time. Like cardboard wrapped in tissue paper. Definitely interested in trying out some aftermarket pads.The new updated sennheiser pads I like as they don't go flat as quickly as the old ones ... but both of my newer pads have come away from the plastic retaining ring
never happen on the old pads
The old ones were softy too
Would highly recommend that Dekoni Audio would be your first stop on your aftermarket pad journey.The new ones sound good, but I really don't like how they feel. Both too stiff and too soft at the same time. Like cardboard wrapped in tissue paper. Definitely interested in trying out some aftermarket pads.
Saying this tho I prefer the sound of the stock pads when they go flatter ....but then I hate the long term comfort.
The amount of times I've replaced the cables you wouldnt belive
Luckily i've never had that problem only with cables breaking under the strain relief at the headphone socket connection ...Did you ever have to replace the spring within the female side of the connectors?
Usually I go with Dekoni pads for my other headphones, but I know the HD 600 is a bit finickier than most about pad matching/tuning. Even according to Dekoni's own measurements, each of their HD 600 pad offerings significantly damps the upper mids and treble.Would highly recommend that Dekoni Audio would be your first stop on your aftermarket pad journey.
I got the HD600's approximately last year, and I loves these headphones at the store so I impulsively bought it. I've enjoyed sennheiser products, but recently I felt like I have lost my way....
I listen to a lot of rap, hip-hop, pop, electronic type music from modern times, so a lot of sub-bass is necessary to have fun.
I got my head caught in a whirlwind of worry after trying on my friend's Hifiman HE400i. Compared to the hd600, they had high highs, and ever since I compared my headphones to others so much.
I've tried other headphones so far: the DT990 Pro X, AKG k371, and AKG K553 MII. I feel like those headphones are great for what they do and provided the color I needed. However, I was so caught up in this comparison frenzy that I forgot the reason why I tried on the headphones at the store. Basically, I lost my way and started to hate my sennheisers just for one specific detail, risking to spend hundreds of dollars for other gear.
I had to take a step back, and get a break for a couple of weeks away from this comparison frenzy.
Trying all the headphones recommended for sub-bass, I felt like all of them failed to achieve what the HD600 did: make electronic digital sounding vocals sound like a person that's actually singing into a mic as if it's classical/jazz/rock music, no EQ required. The DT990s have achieved it, but it requires heavy EQ to get rid of the piercing high's.
Every other frequency is good, but as background music. I totally forgot this recently, trying to search in pursuit of the "perfect sound" to have the sub-bass present.
I'm falling back in love with the HD600, as they feel like I'm in a concert live with the singer; it feels so intimate now that even the lack of sub-bass and other frequencies feels sufficient now, just in the background playing while the vocals are right up to my ears. These are the best neutral cans in my books, where the vocals are here to the point you can forget about everything else and even then they fill the gaps sufficiently. These cans aren't colored at all, bit I'm starting to see why others love non-colored cans and why the HD600s are a fan favorite
... only 48 !!! ... ... plenty of time to be ... ( ... psst, try 70).I've been really enjoying the HD600's the way I have them set up. Which is with some PEQ (low bass almost up to flat, slight midbass hump flattened, 1khz-4khz area down 3db), which really helped my enjoyment of them, as well as a balanced XLR cable that gets the most out of my bryston bha-1 amp.
The cable gives some more headroom, a little better soundstage, and slightly better clarity and detail.
The only other upgrade I've been considering are the ZMF auteur classic, which I've read several times are a super HD600. Main concern for me is I won't do without that HD600 tone.
Very luckily, I found a pair of Auteur classics for sale in Canada, in excellent condition, and just after they were listed. A very rare find, so I couldn't refuse.
But I was also hoping they weren't as good as people are saying and I could save some money by reselling them.
Only have an hour on them so far, but they indeed are a super HD600. When starting the first song the differences didn't seem really noticeable.
But after a couple songs and several more later, the clarity and detail, and better sub bass extension revealed themselves to be a good step up. The soundstage is also a little better and a little farther away. There is no noticeable midbass hump, which is what I also really like. And most importantly, that amazing natural tone is still there.
This is while using the stock perforated lambskin pads. I haven't tried the suede pads and from what I've read about the sound differences, I probably won't bother.
After the improvements from the bha-1 and balanced cable into the 600's, I was about ready to call it done. But despite the cost of the Auteur's, I'm glad I didn't.
And they're only going to get better yet, because the improvements are quite noticeable even without EQ or a balanced cable. So I have another cable on the way, and I'll spend some time setting up PEQ.
Headphone system endgame achieved.
Now hopefully I'll feel the same about my new and best stereo system when I finally get a chance to set it up.
I've spent way more lately than I wanted to on everything, but I'm 48, and I've played the upgrade game long enough. I want my systems to be done and finally want to be satisfied with my choices.
Agreed, some models like the sheepskins are prone to this. Have you personally tried all their model lines with the HD600? I was really quite surprised that the Elite Hybrid pads are not as drastic of a change in the primary sound signature as other Dekoni models... most especially their Elite Velour line which I have a hard time distinguishing between them and the stock Sennheiser stock OEM pads on all but my most familiar music tracks and then it is not a one is better than the other but simply rather a very minor but still pleasant difference in presentation. Maybe worth your time experimenting with the Hybrids or the Elite Velours, you might be surprised . Good luck.Usually I go with Dekoni pads for my other headphones, but I know the HD 600 is a bit finickier than most about pad matching/tuning. Even according to Dekoni's own measurements, each of their HD 600 pad offerings significantly damps the upper mids and treble.
Think I might shell out for the pricier ZMF pads since it sounds like the Dekoni ones alter the tuning too much.
If you're sick of the upper mid range on these you can check out my mod. Measurements are courtesy of JK47. Mod requires custom cans mod and will work on hd600, hd650 and hd6xx. I'm working on a 58x variant as well. Best of all, you can print it for free.
