ThEvil0nE
- Mar 30, 2010
New firmware felt a little snappy and so far wifi has been more reliable.
Can agree the new firmware seems to be tightly refined.New firmware felt a little snappy and so far wifi has been more reliable.
Oooh, thanks to this thread I now realised there is a new firmware. OTA Update done and now listening again.
Seems there is a new version of Hiby music installed.
Will be interesting to see if there are obvious differences
I download the OTA update and as the V6 reboots to install, it shoes the little robot with 'error', and boots into the old Firmware. I've done this a few times, and also tried install 'later' and the same error occurs. There is nowhere on the Tempotec site to do download a local update of the FW. Any ideas guys?
@dharmasteve: Have you tried the usual?
Doing it again, doing it while on external power? Lastly, doing a factory reset and trying it again?
The error *sounds* like corrupt download...
you select update on the system panel, on ota update you click on the three dots top right and select "local updates" and the the file you copied overI just managed to get the FW 1.10 from the Tempotec Site on my PC. How do I install locally. Do I put it in the "Root" folder and reboot?
I had trouble with the OTA update too. The way you get it done is to completely remove your micro SD card, and then initiate the download. This is how I had to do it to get to the new one.I just managed to get the FW 1.10 from the Tempotec Site on my PC. How do I install locally. Do I put it in the "Root" folder and reboot?
Wow! You deserve some praise. Well done my friend. You are totally right. For everybody....take out your SD card before you do an OTA update. Thank you friend, you have saved me a lot of migraines. Excellent. The only thing is when I open Plugins in the audio settings I do not have 'dynamics', as another has mentioned.I had trouble with the OTA update too. The way you get it done is to completely remove your micro SD card, and then initiate the download. This is how I had to do it to get to the new one.
Anybody else’s V6 having Apple Music say it’s rooted and no longer available? Any work around found yet?
