The iBasso Dongle DAC Thread – DC03 Pro | DC04 Pro | DC06 Pro | DC Elite | ...
May 7, 2024 at 6:14 AM Post #1,126 of 1,185
Or you can get a Moondrop MIAD 01 DAP Phone. No more need for a dongle.
The Elite dongle give a special sound you may not found with the MIAD, so it will not resolve the issue.
He wants to keep the Elite sound in a light solution. I can understand what he means by this, and avoid a big stack with a source, a power bank and the Elite.
May 7, 2024 at 6:53 AM Post #1,127 of 1,185
Thanx for undestanding, this is exactly what im aming for.
Btw, this M300 sounds surprisingly good on its own. It has a lot of power, great battery life even when streaming, fast charging, smooth and very responsive OS and fantastic form factor.
At first it sounded quiet, even with a very efficient iems but there are two volume adjustments- Master volume and Media volume. Media volume is set to 50%. When i set it to 100%, it unleashed gobs of power. It can now drive Sundaras to very loud levels.
When it comes to the dac, it isnt as refined and smooth as the Elite but it isnt harsh either. Its a very balanced and spacious sound. To my ears, it sounds bit better than the Pioneer xdp300r lol. The sound is bit fuller and pleasant.
May 7, 2024 at 7:50 AM Post #1,128 of 1,185
I’m gonna try to find an Elite, I am very curious about this sound.
In the end, what I understand is that an Elite with his own battery inside would have been the solution.
Something like a Qudelix 5K.
May 7, 2024 at 11:31 AM Post #1,130 of 1,185
Hi,
I have FiiO BTR15 and if I use single ended (wired) it will not use Dual DAC, but just one, i.e., forcing me to use balanced just because of that. Does this happen with DC04 Pro wired?
No.
May 13, 2024 at 5:33 AM Post #1,131 of 1,185
had my dc06 pro just died all of a sudden on me. suddenly heard a pop and the right channel started being alot softer than the left.
my dc03 pro also had a loose jack issue too. thats really bad quality considering both died less than a year of use
May 13, 2024 at 3:15 PM Post #1,133 of 1,185
Simple, contact the seller and have them send it in for repair. There is nothing made that will not break.
May 13, 2024 at 3:29 PM Post #1,134 of 1,185
Please contact me at paul@ibasso.com for an RMA or you can go through the dealer.
iBasso Stay updated on iBasso at their sponsor profile on Head-Fi.
http://www.ibasso.com/ paul@ibasso.com
May 13, 2024 at 11:15 PM Post #1,135 of 1,185
May 15, 2024 at 10:51 AM Post #1,137 of 1,185
Joining the DC-Elite club. After a lot of research it seemed like the no brainer choice. Excited to get it tomorrow!
May 15, 2024 at 12:45 PM Post #1,140 of 1,185
Thanks for responding! So the amp doesn't factor in as much to the sound signature? I've heard good things about the JDS Labs Atom amp. Also, I saw a Schitt Magni Heretic for $60. Are those viable options?
I don't know so much about head amps than I know about DACs. The Heretic is very well reviewed so I guess you can't go wrong there. The only thing about it that is missing is balanced inputs and outputs. Just RCA and 6.5mm Single ended.
