Aevum
- May 15, 2007
Im having issues with 0.78mm cables.
Not sure if its becuase im using cables in the 20-30€ field, or just that chifi build quality is mid but im seeing a trend with the last 3 IEM´s i bought with surface 2 pin.
Blessing 2, Soundrhyme SR 5 and ZiiGaat dos cinco.
Basicaly the 2 pin just unplugs and the IEM falls off the cable, i also have the EM6L from Simgot but that has the KZ/QDC shielded 2 pin that has a piece of plastic apart from the 2 pin that grabs on to the cable,
Maybe cheap cables have this issue and i should get a good one, or maybe build quality is mid, or im damaging the connectors due to cable changes ?
any ideas ?
any ideas ?
