A portable player with built in amplifier?
Jul 23, 2017 at 10:15 PM Thread Starter Post #1 of 12
BassHeadJim
Singapore
Hi folks,
I'm searching for my next set of headphones, but some of the options I'm looking at need amplification. I really don't want to have to carry around and keep charged an amp (I already have a Fiio E11) as well as my phone and potentially a player too.
Is there a portable MP3 player anyone can recommend that is capable of driving 100+ (or even 200+) ohm cans?
Thanks!
Jul 24, 2017 at 1:57 AM Post #2 of 12
Hey,
(For reference) FiiO X3II is almost as powerful as FiiO E11.
Your listening levels play an important role here.
Jul 24, 2017 at 6:41 AM Post #4 of 12
+1 for X3II, very powerful little guy
Jul 24, 2017 at 9:19 AM Post #5 of 12
Hi folks,
Fiio X5 and X3.
Jul 24, 2017 at 3:45 PM Post #7 of 12
You could wait for the X7 Mark II with swappable amp modules
Jul 25, 2017 at 9:49 PM Post #8 of 12
Thanks for the responses everyone!
I went to my local store and tried as many of your suggestions as they had in stock. In the end I opted for an E17K Alpen 2 DAC amp. I know I said I didn't want to cart an amp around, but I figured it was no worse than carrying a player and a phone.
What swung me was the ability to use it as a DAC driven from my laptop at home & work. After thinking about it I realised the convenience of being able to just play anything from my network drives and Spotify over having to keep uploading stuff to a player would make a much bigger difference than I previously thought.
I have a bad habit of just putting a load of albums on devices and then leaving them for way too long - basically until I'm terribly bored of hearing the same stuff too much.
So far I am absolutely loving the E17K. The extra power and the ability to give a little boost to the bass & treble settings has made me fall in love with my M50Xs all over again. I can't wait to try it with my incoming Fostex TH-X00s.
Thanks again for all the suggestions!
Jul 25, 2017 at 9:58 PM Post #9 of 12
When you get the TH-X00's your going to say why would anybody want the M50's.
Jul 25, 2017 at 10:22 PM Post #11 of 12
Hopefully I'll still like them enough for the commute - I don't want to break the TH-X00s like I have so many others :)
Pretty hardy build but if you jump on them I'm sure they will break ; )
