shak85
- Dec 22, 2010
Hello everyone.
I m new to portable amps and i have a question. An amp basically amplifies the volume without distorting it . I have hippo vb which are basically for bassheads. Is it possible when connected to an amp to make the bass less impactful? I mean can an amp change the sound of hippo vb to produce less bass.
My logic says no because it amplifies the sound of hippo vb and can't change its sound signature. I m referring to amps with no bass boost (pa2v2).
Thanks
Sent from my iPhone using Tapatalk
Thanks
