- Dec 27, 2016
Symbio in stock!
Just placed an order. Will give them a try for my IE800.
Symbio in stock!
Are these similar to Sony hybrid tips? Anyones owns both?
Sounds different.
The Hybrid do affect the overall sound a little.
These are more neutral. Dont affect the sound much.
Hi guys
Does anyone has tried with VEGA or Andromeda ?
Hi guys
Me, with the Vega.
Hi guys
Hi guys
Good seal
Dont affect the sound much like others do
Comfort, i would say depends on the size you choose.
For me the small is too small for me and medium is a bit big for me but able to fit. I felt lump in my ear. But after a peroid of use, i think the foam soften a bit, so now is comfortable for me.
But anyway the Wide bore version is releasing like stated above.
