Acoustic Research M2 Audiophile-Grade Hi-Res Portable
Feb 3, 2020 at 1:22 PM Post #1,516 of 2,162
Sure, when I get chance, need to find a simpler way than I did for rooting and somewhere to store all the apps etc
I have patience. Thank you in advance for your work
Feb 5, 2020 at 5:55 AM Post #1,517 of 2,162
Feb 5, 2020 at 7:28 PM Post #1,518 of 2,162
Let us know your thoughts about this dap. I listen to it right now with Jh audio Roxanne performance series and the sound is magical
Feb 5, 2020 at 10:32 PM Post #1,519 of 2,162
Sound is very enjoyable no issues with its sound. Size is great , power is plenty. My issue is how Im viewing my folders. I put all Metal albums in a folder labeled "Metal". I put Synths albums in a folder labeled "Synths" but when I view folders in the AR Dap it puts every album in one big folder all together.
Feb 5, 2020 at 11:39 PM Post #1,520 of 2,162
Thanks Nayparm , Neutron installed and working.
Feb 6, 2020 at 3:45 AM Post #1,522 of 2,162
What size SD card will work well on the M2 ? 200 , 250 , 400 ?
Feb 6, 2020 at 10:59 AM Post #1,524 of 2,162
Feb 6, 2020 at 4:41 PM Post #1,526 of 2,162
Here you go guys, sorry its breif, I don't get much free time. Download all these and install in this order I found an easy way for you guys to root, I went the hard way round with command line stuff initially.
Official Kingo-root (not fake version and not kingroot crap etc)
https://www.apkmirror.com/apk/kingo...ngo-root-4-5-6-android-apk-download/download/
Use this to install busybox (command line tools needed by Viper4Android and Xposed)
https://m.apkpure.com/busybox/stericson.busybox/download?from=details
Viper4Android
http://download888.mediafire.com/mcikmhwcwhsg/xonl4jha2e4vez1/ViPER4Android_FX_v2505.zip
Xposed installer
https://dl-xda.xposed.info/modules/de.robv.android.xposed.installer_v33_36570c.apk
Gravitybox Xposed module
https://dl-xda.xposed.info/modules/com.ceco.gm2.gravitybox_v134_b4e361.apk
Note: Viper4Android will work for Neutron and any other Android 4.3 compatible music app. It wont work for the stock UAPP players.
You will need the ARM7+NEON version of neutron
The older Hiby V3.00 (none mseb version) is android 4.3 comparible, get it from the apkpure website or install the apkpure app and install from there. best web browser that ks compatible and works properly is firefox from apkpure.
Feb 6, 2020 at 7:02 PM Post #1,527 of 2,162
Some of the things you can do with gravity box
Transparent status bar, change battery icon, add remaining percent, change colour, centre clock etc.
Fully customize notification shade drop down.
Additional options in power menu, Extended desktop for full screen apps, can automatically enable pie controls slide up from bottom etc.
Feb 6, 2020 at 8:02 PM Post #1,528 of 2,162
IMG_20200206_235415.jpgIMG_20200206_235446.jpgIMG_20200206_235511.jpgIMG_20200206_235550.jpgIMG_20200206_235607.jpgIMG_20200206_235626.jpgIMG_20200206_235645.jpg
I just noticed that you tried the new Fiio M15, how would you compare the sound between the two. I only care about sound quality. I listen to the same type of music as you. Also, which is your preferred dap, I am interested only in sound quality because I load my music and don't really care about streaming and stuff
