Ninja Theory
Is there a way for Roon to see the ARM2 as an endpoint?
Rebooted a few times. The odd thing is that the M2 Music Player doesn't play songs. They sit at 0 seconds. Tidal plays but there's no sound. I'll keep troubleshooting.Try a reboot, not had that before. I dont use tidal and not a roon user so not sure what its capable of.
Nope just followed the steps, BusyBox, Viper, Exposed etc. And yep, latest firmware.Did you do anything else after following root and google play ? You can always factory reset and/or reflash the firmware, speaking of firmware are you on the latest ?
Just reflashed the stock firmware and it's working again... @Nayparm if you have time to check out getting the Roon app to work, I'd be eternally grateful !
I tried to follow your steps and I got stuck at BusyBox, it says that some settings don't let the app work. It would be great if you could make a video with the steps that need to be done, that way even people like me that are not so familiar with android can install all this stuff. It would be greatly appreciated. I know you don't have the time to focus only on this, but the man can hope. Keep up the good workNo idea what happened then pal. As you can imiganine I've done it fair few times on several devices.
Yeah I read up, I'm sure the issue is on my end. I'll mess around again soon, I'm pretty familiar with rooting. For now, I'm just reveling in the supreme SQ.No idea what happened then pal. As you can imiganine I've done it fair few times on several devices.
The BusyBox bit can be confusing because of all the check boxes. Basically, let it load up and then click install (bottom left). Once installed you will get a pop-up box confirming it's successful. Then you can close it and move on. Pretty straight forward once you know the above.I tried to follow your steps and I got stuck at BusyBox, it says that some settings don't let the app work. It would be great if you could make a video with the steps that need to be done, that way even people like me that are not so familiar with android can install all this stuff. It would be greatly appreciated. I know you don't have the time to focus only on this, but the man can hope. Keep up the good work
I installed the app but when I tried using it but I have a notification saying some settings that I have don't let the app work
Thank you, I will tryAh ok, it's not rooted then, once you install Kingo-root you need to run it, tap the screen and wait for it to complete rooting (takes a while trying all the exploits) after the reboot install busybox and run it and hit install at the bottom left.
