jetpacksam
Hello From Seattle,
I did a search and didn't see this.
I will be receiving a pair Of Klipsch mode M40's as a replacement for a set of x10i's {dead mic} on Wednesday. {medical issue, ear phones = ouch}.
This is my first pair of active noise cancelling headphones.
Normally my pre-use exercise routine is:
Fully charge my iPod classic 160gb, set it on shuffle, put the volume at about 35 %, go to all songs, and hit play, leaving the headphones on a pillow.
After the iPods battery expires, I unplug the Headphones, letting them "rest" while the iPod Recharges, then repeat this at least 3 times total, about 90 Hours minimum.
I do this before i listen to them the first time. Sure, I try them on, but I've long been convinced {placebo? maybe} that there is a difference,
There was in the HD 280-Pro, The x10i and in the Shure scl5's. So short question long:
Active noise cancelling ON OR OFF during my pre-use exercise routine?
If you like, I could post my thoughts on these in a month or so.
