- Jun 13, 2016
FREQUENCY RESPONSE
DESCRIPTION
Hi-Res Audio Certified | What does it mean?
ADVANCED GT3 in-ear monitors are certified by the prestigious Japan Audio Society (JAS) to produce frequency over 40,000Hz making it an essential part of high-resolution audio (96kHz/24-bit) listening experience.
Extreme-resolution Audio
ADVANCED GT3 in-ear monitors provide an unprecedented level of resolution and sense of space through its integrated monitor design that consists of the proprietary driver, stainless steel acoustic housing, and quad-braided silver-plated copper cable. The resulting audio is a stunning mix of clarity, micro-detail, speed and extremely wide sound-stage.
Proprietary Driver Technology
The GT3's proprietary driver uses light-weight voice coil which is up to 30% lighter than a conventional counterpart. Its tremendously improved treble response is the core tuning philosophy of the GT3's driver. It is designed to pick up and replicate the smallest nuance in the high frequency above 4kHz and works incredibly well with the sound of acoustic instruments. The proprietary multi-damping structure of the driver aids in the sub-bass extension that does not affect or bleed over the mid-bass region, making its sound characteristic extremely similar to that of a pair of full-sized electrostatic headphones.
Indestructible Chassis, Tuneable Sound
The GT3 utilizes CNC-machined, elegant and indestructible stainless steel acoustic housing that minimizes in-chamber acoustic resonance and driver flex. 3 pairs of tuning filters are included to adjust the sound signature to each user's preference. The tuning filters are designed to adjust the 3kHz frequency, of which the human hearing is the most sensitive at.
Highly Scaleable through Amplification
The GT3 is highly scalable with additional amplification as it gains a boost in the sub-bass and mid-range, unlocking the true potential of the driver. If you are happy with the sound of GT3 directly through your source, you will enjoy that much more when it is properly amplified.
Interchangeable MMCX Cable
There is a total of 2 interchangeable MMCX cables included: a premium quad-braided silver-plated copper cable with a 3.5mm gold-plated plug, which is specifically designed to pair with the GT3, and a mobile 3.5mm plug cable with a 3-button remote / mic that is compatible with both iOS and Android phones.
Accessories
- 1 MMCX silver-plated copper quad-braided cable
- 1 MMCX mobile cable with 3-button remote/mic
- 3 pairs of black foam tips
- 3 pairs of black single-flange silicone tips
- 3 pairs of black dual-flange silicone tips
- 1 premium carrying pouch
- 1 leather cable tie
- Driver uni: t Light-coil multi-damping dynamic driver
- Impedance: 32ohm+/-15%
- Sensitivity: 92dB+/-3dB at 1kHz
- Frequency response: Ultra Wideband 10Hz – 40kHz
- Rated power input: 1mW
- Input power: 5mW
- Cable composition: Silver-plated copper
- Cable length (SPC): 1.5M
- Cable length (Mobile): 1.2M
- IEM connector: MMCX
- Plug: 3.5mm gold plated
I don't know about you guys, but I'm pretty excited for this. There's a lot of parallels to be made between this IEM and the Macaw GT100s (even the name!). Hopefully this one lives up to the price, since it's up for pre-order at $200.
