average_joe
- Dec 5, 2008
The Trips are very different than the Reference according to Marc.
Thanks for the correction. I'm assuming the difference other than the obvious BNC connection on the Livewires is with the tuning and/or drivers (never quite understood why Marc wraps the drivers for concealment).
I had the Livewire Trips, which I'm not 100% if it's still tuned the same with the same drivers and configuration as the Reference, but if it is, the 4A is a better sounding ciem in terms of wider stage, and better micro details. The only area that I recall that the Reference may had bested the 4A is with bass quantity. I recall the 4A sounding much more musical over the Trips. I hope that helps some.
You must be releived!Thanks for the info but as it turns out my wife had mistakenly put them in a different bag and I came across them yesterday. So excited I didn't loose them.
You should still get some Alclairs and do a comparison for us. I think you "have to" now.
