AudioThief
- Feb 15, 2017
Hi guys.
Budget is around 900$ max. I am looking for a amp+dac or just amp depending on cirumstances. Basically, I am more limited by the fact that new equipment is expensive and scarce, while used equipment is cheap but even more scarce. I cannot import because of insane import taxes in Norway.
Anyways.
I am looking at the following right now
Maratanz HD-DAC1 (NEW)
Fostex HP-4BL (NEW)
Burson Audio HA-160 (used)
Lake People G109P (NEW)
Atrox V2 (NEW)
Basically, I'm somewhat confused about what I should be purchasing. I already own the dragonfly red. I could use this as the DAC and then just get an amplifier. But if I can improve the sound by upgrading the dac, why not?
I tried a very high end Hegel H360 (4,000$ amp+dac) and it sounded fantastic with a very deep bass, awesome seperation and blackness. Lightyears ahead of my DFR. Now was this a combination of amp and dac being better, or just amp? Do I need to get maximum amount of power? Is it always better to get a standalone amp and a standalone dac and pair them?
The Atrox V2 is a 235$ amplifier which is extremely powerful - much more powerful than any other amp I've ever seen, home made by an engineer here in Norway. If power is what makes a good amp, then this is a good amp. It has also been called "dark" or with a full sound, with a lot of low end - which should pair well with the somewhat bright TH900.
So if a powerful amp will cover that part, I need a good DAC to pair with my TH900.. Now what would that be?
Or should I buy a combination? The marantz HD-DAC1 looks fantastic and has gotten great reviews, but am I wasting money on functionality i.e could I achieve the same sound quality or better with a powerful no nonsense amp such as the Atrox V2?
How important is it that I have a very powerful amp? The HP-A4 isn't really powerful, but has gotten good reviews as well and has both amp+ dac.
I am just very confused.
Anyways.
Fostex HP-4BL (NEW)
Atrox V2 (NEW)
